honda cr500af rekluse clutch
15 replies to this topic
  • Kenny H
Posted 15 August 2012 - 07:15 AM
Hi everyone, I ride a Honda cr500af, '01motor, and I want to put a rekluse clutch in it but not sure which one to use. zpro or exp. Does anybody out there know which one would be best for a 500 2 stroke? thanks, Kenny H
  • Kirkes
Posted 15 August 2012 - 07:04 PM
I have one in my cr 500 afc.  It is the E z start.  the only one they offer of the 500.  Order 6 more TC balls when you get it.  Or the clutch will slip to much at low rpm, our bike make more power down low then the stock clutch set allows for.
  • motobando
Posted 16 August 2012 - 10:41 AM
I run an EXP in my 09 450 and love the way it feels, plus I can still use my clutch as normal with the lever.  The EXP with heavy springs will not slip as much in your 500.  It'll probably slip just enough to give you more traction.  Thought about getting one for my cr250 but the stock clutch feels fine...
  • Kenny H
Posted 16 August 2012 - 12:05 PM
I dont know alot about the clutch, so are you saying I can buy extra tc balls and install them along with what comes with the kit?
  • Kirkes
Posted 16 August 2012 - 06:28 PM
There are 21 balls in all.  They sling out as the rpms increase and apply preasure to the clutch pack.  The clutch comes with 6 tungston ball (TC) but you need 6 more for the 500 not to waste the clutch to soon.  I love my rekluse clutch.
  • seanmx57
Posted 21 August 2012 - 07:58 AM
they come with 27 balls on the pro version, 12 TC's minimum for happy rides. they come with 6 TC's
  • seanmx57
Posted 21 August 2012 - 08:01 AM
The exp core won't handle the extra power, they are barely doing it for good 450's.
  • Kirkes
Posted 21 August 2012 - 08:51 AM
thanks sean.  I guess I remembered it wrong.
  • Eddie8v
Posted 22 August 2012 - 03:18 PM
Sean is right, use the z-start pro.
  • Kenny H
Posted 24 August 2012 - 07:23 AM
Hey thanks alot guys for the imformation. I told the man at rekluse your imformation and he said I'm wasteing my money on extra tc balls. I dont think he has a cr500.
  • BurntTimber
Posted 24 August 2012 - 07:26 AM
Z-Start Pro let's you use the clutch lever too (regular Z-Start doesn't but is good for those who want to run left hand rear brake lever).
One thing to note for those running hydraulic clutches, my buddy had the EXP in his KTM 450-SX and I've found he has to adjust it a ton, often mid ride (I've never had to adjust since putting mine in). Might just be that he's doing it wrong, but after seeing his experience I'm that much happier with the pro.
Edited by CriticalSwass, 24 August 2012 - 07:26 AM.
  • Kenny H
Hi Sean, Kenny H here, Do you also think I should buy 6 extra tc balls for my 500? I'm learning as I go here from rekluse man and you guys on Thumpertalk.
  • Kenny H
Posted 24 August 2012 - 07:31 AM
Let me ask you, The rekluse man said not to buy extra tc balls for a z-start pro for a cr500 but others say to buy 6 more what do you think?
  • gman255
Posted 24 August 2012 - 08:04 AM
I'm with the 500 Junky's above.
Also ruining the Zstart Pro in my 500AFc. The initial set up with recommended 6 TC was ridiculously pathetic! I all most took the clutch out- It engaged way to late... After going out to 12 TC it started to shine! Going to try 15 TC one of these days
12 TC really should be the recommended set up from Rekluse!
Its what we're all running-  Mickfly
Edited by gman255, 24 August 2012 - 08:07 AM.
  • Kenny H
Posted 24 August 2012 - 09:11 AM
To all 500 junkies, You made up my mind, I'm ordering the 6 extra tc balls, thanks
  • seanmx57
Posted 27 August 2012 - 06:50 AM
12 minimum unless you want it to act like a hot rod race car with a high rpm kick in rpm. with 12 or more you will have the low rpm pull that 500's use frequently.
They should come with 12 for the 500's, 6 just pisses ya off cause it slips so much at low rpm.
