DRD Slipon
1 reply to this topic
  • wrwest
Posted August 14, 2012 - 09:41 AM
I would like to know if I buy a Full system DRD exhaust - this is the header and full silencer system - For a 2009 Model WR 450 F will I have the header over the oilfiterbolt problem ?
Can I use the silencer part as a slipon only or is there parts missing when you buy a "slipon" only ?
I presume the DRD header is thicker than the standard Yamaha header ?
Does the DRD have a Clamp on the silencer part ? Does not look like it from the DRD site?
  • wrwest
Posted August 15, 2012 - 04:19 AM
Ok found some info all over the net , A Drd slipon has a sleeve to fit a st WR header and has no clamp system .
Top oilfilter cover bolt access is a problem!
Full system header is verry exposed and has no gaurd.
