i just put a new motor in my ranger (00), ive been busy and the project took me a year to do. but now when i was all fired up to start it it wont turn over and the theft light blinks very fast. i waited till it throws the code and i have a Blink, pause, blink blink. so i believe that is a 1:2 but i couldent find info on it anywhere,
couple notes:
all i did is install i new short block. everything is the same.
just installed a new battery
used the same key
all fuses are good
any thoughts?
need a ford expert on a theft light/nostart
Started by
davecarrr414
, Aug 14 2012 03:51 AM
5 replies to this topic
Posted 14 August 2012 - 04:32 AM
try this, let it hooked up to the battery overnight, about 24 hrs, if the PCM was disconnected for a year, it needs to relearn it's memory, I had a situation w/ a 01 escape, in which i replaced the PCM, and thats what happened, its just a guess for your case, worth a try.
Posted 14 August 2012 - 04:49 AM
Im a ford tech, it sounds like the keys lost their programming. you will need 2 keys and have them programmed. I think some locksmiths can do it cheaper than having it towed to a dealer.
Posted 14 August 2012 - 07:23 PM
Does it crank and not start or no crank at all. With an unrecognized key it should crank start and die. If it starts and dies I think the ford dealer will have to use a [NGS] an old ford scanner to get the ranger to recognize the keys . There is a collar around the ignition switch that excites a chip in the key and recognizes it's signal back . if it dont crank it is somthing else [ I was a ford tech from 93 to 02][back in the olden days]
Posted 15 August 2012 - 03:22 AM
yea its deffanitly a PATS issue, im calling a few lock smiths today to see if they can program me some new keys. thanks.
