  • Instagram
Related Reviews
Yamaha WR450F 2012
Last review by Ptch5636
Related Garage
Yamaha WR450F (2012)
Owner: Strykerlover
Added on September 16, 2016
* * * * * 1 votes
2012 WR450 Starting woes
Yamaha WR450F 2012
500 replies to this topic
  • AaronS
Posted November 24, 2013 - 02:01 PM
Boats.net/ Partzilla informed me that the part is not available anymore through Yamaha anymore. I ordered something through another Yamaha dealer, but I don't know what the part number is. Its supposed to do the same things and should be here early next week.
  • cassinova90
Posted November 24, 2013 - 03:31 PM
I'm interested to see what you end up with . I'm keen to know the part number when you get it ..
I tried to order through boats.net a few weeks ago and found the same thing no longer available .
I got mine through eBay .
  • alstar250
Posted November 24, 2013 - 05:56 PM
I have been watching this thread even before I brought home my 2012 WR450 (which was this past Wednesday 11/20, got it super cheap too) and I have had no such issues. When its cold I always kick it after pulling the knob, but once she's warmed up I have little to no issue with E-Start, even in gear (as long as the clutch is pulled in)
One question, the Yamaha website states the 2012 as having a CDI ignition and the 2013+ as TDI - Anyone know which is which and whats the main difference? Just wondering if that may have anything to do w/ starting it up
Edited by alstar250, November 24, 2013 - 05:57 PM.
  • Jolly705
Posted November 25, 2013 - 02:40 PM
I was wondering the same thing about the CDI, I also picked one up on this past Saturday for cheap and have been having trouble starting it. I think I am going to hit the dealer and ask for the sniffer test that was mentioned earlier in the thread.
  • Ride-n-Hard
Posted November 25, 2013 - 03:18 PM
I asked this question before but don't think I got an answer. after you made these adjustment have you rechecked the settings with the gytr tool?
I find this interesting because I've stalled my bike on the trail and it started back up. do you think its a temp thing that is causing it or elevation or....?
  • vlxjim
Posted November 25, 2013 - 04:11 PM
There is nothing that you can check but the Map. The map does not change if you adjust the CO levels. The map from the GYTR is just a lookup table that the ECU looks at to off set the base settings (tuning). The CO level adjustment is a separate lookup table that is adjusted by the FI tool. It should have been part of the GYTR's tuning parameters. But do to CARB and the EPA It's a dealer only adjustment. This is not only dirt bikes but its the sane for street bikes, snowmobiles, outboards, and boats. And the FI tool works on all of these built by Yamaha.
  • vlxjim
Posted November 25, 2013 - 04:14 PM
The CDI is a hotter but shorter spark and rev's higher than the TDI style. CDI also cost more. The 2010 YZ's are CDI but are now TDI. I would think both are good on the WR's.
  • bobpara
Posted November 26, 2013 - 05:55 AM
At a glance, it looks like the extra drag of being in gear with the clutch in creates too much resistance for the starter (1/2 of the clutch is spinning when you start or kick a bike in gear with the clutch in)When in neutral with clutch out there is less resistance.
I know my '06 has a rather marginally designed starter motor, mine, like many others, will not physically turn over if the piston stops at TDC. A very rare occurance, but when it does happen you think you have a dead batt or a bad starter motor
  • AaronS
Posted November 27, 2013 - 02:44 PM
I just received the tool from Honda east Toledo and it is the 90890-03182. Its identical to the others using the same part number. The Yamaha sticker on the box also has the number Y070515T and a separate sticker has the letters K@L with the number 35 3028. The parts guy mentioned that it was coming from the Yamaha warehouse, so I don't know why he had no problem getting it when others say they cant. I plan to try it out tomorrow, with hopefully the same results as others have had.
  • cassinova90
Posted November 27, 2013 - 10:32 PM
Should have no problems. Green wire to airbox, alligator clips to battery .
Ignition off. Hold down menu button and while holding turn ignition on .
Press up , should read co, press menu then adjust accordingly .
Turn off ignition.
Repeat steps to check .
  • Navaho6
Posted November 28, 2013 - 08:51 AM
How much $ for this tool?
Lexx makes an efi controller for the YFZ450 quad. I wonder if that would also hook up to the WR ?
  • AaronS
Posted November 28, 2013 - 12:25 PM
$ 185 shipped from Ohio to Maryland. The receipt shows a msrp of $249.
  • cassinova90
Posted November 29, 2013 - 05:32 AM
Turn off ignition.
Also if you are using it for diagnostic the codes e.g. D02 etc are all in the Yamaha WR service manual
  • JDLowrance
Posted November 29, 2013 - 08:02 PM
Well, not sure what happened to my new Earth X battery but it wouldn't start the WR today. Started the bike fine over the last few weeks in the garage.
Got out to Gorman this AM and click, click, click. Had to kicj=k the bike all day which wasn't an issue as it fires right up. Will be contacting Earth X to get a replacement battery under warranty. Will let you all know if there are any issues getting the replacement.
  • funt
Posted November 30, 2013 - 02:42 PM
Maybe I should have got the power commander v.  That's a lot of extra wires and crap to have under the seat though.
  • AaronS
Posted November 30, 2013 - 03:45 PM
I followed Cassinova's directions, and it seemed to work properly. I don't have any way to check the exhaust, so I set it to 8, it was at 0. I just need it to warm up or dry out a little to see if there is an improvement.
Thanks for the help everyone.
  • boston460
Posted November 30, 2013 - 09:41 PM
Anyone have a Chinese fi diagnostic tool that doesn't connect, have you tried just the center pin plugged into the bike, like so [attachment=102241:1385876381111.jpg
Mine works regardless, so I can't test to see.
Edited by boston460, December 01, 2013 - 04:58 AM.
  • boston460
Posted November 30, 2013 - 09:46 PM
Edit: combined post.
Edited by boston460, December 01, 2013 - 04:57 AM.
  • BoiseBee
Posted November 30, 2013 - 09:59 PM
Has anyone that's got a Chinese fi diagnostic tool that doesn't connect tried just having the center pin plugged into the bike, like so http://www.thumpertalk.com/public/style_images/tt34/attachicon.gif 1385876381111.jpg
Yep, tried it.... No dice.
  • scott525
Posted December 01, 2013 - 05:48 PM
Has anyone tried one of these?
http://www.yoshimura...gement_PIM.aspx
Just orded their rs4 and saw this.
New '11 WR450 or '12WR450 by new605guy
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  76 replies
2012 wr450 plastics by Fvmcboy99
  • 3 replies
2012 wr450 exhaust? What fits by Fvmcboy99
  • 20 replies
2012 wr450f Idle issue by WeekendWarriorz
Dirt Bike   Dirt Bike Technical Forums   Intake - Jetting / Fuel Injection
  • 0 replies
2012 WR450 IMS fuel tank by Dave WR450
  • Hot  30 replies
