  • Instagram
Related Reviews
Yamaha WR450F 2012
Last review by Ptch5636
Related Garage
Yamaha WR450F (2012)
Owner: 51fiftey
Added on September 16, 2016
* * * * * 1 votes
2012 WR450 Starting woes
Yamaha WR450F 2012
502 replies to this topic
  • funt
Posted October 29, 2013 - 03:57 PM
These are supposed to idle at like 2000 rpms, right?  My vapor tach says mine idles at 1300 something.  I can turn the knob in and make it slower but when I turn it the other way it seems like it stops around 1300 rpms.  Maybe I have the vapor set up wrong.  Do you guys have this problem?  Maybe enrichening it would speed up the idle.  Edit: I changed the pulse per rev from 1 to .5 and rpms are in spec.
Edited by funt, October 30, 2013 - 11:42 AM.
  • vlxjim
Posted October 29, 2013 - 09:06 PM
If you have a GYTR power programer you can plug it in and read the RPM off the ECU in real time. It should adjust right around 1600-2400 rpm's. And adding more fuel did not change my rpm setting.
Edited by vlxjim, October 29, 2013 - 09:07 PM.
  • BoiseBee
Posted October 29, 2013 - 10:49 PM
Well, I ordered one up, so I hope I got the right one.... Mine says its for the SYM motorcycles and looks like it has the correct cable, but I noticed it says "ED88" above the display instead of "VD001" like the ones posted previously on here.... other than that it looks identical.
  • boston460
Posted October 29, 2013 - 11:51 PM
Don't worry, the one I ordered was a ED88 in the photo but the one I received had VD001 printed on it.
Edited by boston460, October 30, 2013 - 12:52 AM.
  • MidlifeCrisisGuy
Posted October 30, 2013 - 07:30 AM
I get that quit often.  When I stop cranking, it appears to be stopped at top dead center and the starter isn't strong enough to push past it.
x2
I have the same thing happen.
I dare you guys to try not using the starter for a day. After you get used to kicking, you won't even miss it.
  • woods-rider
Posted October 30, 2013 - 07:39 AM
Yes I will. I kicked for years and love having the button!
  • vlxjim
Posted October 30, 2013 - 07:41 AM
As good as mine starts I would miss it. But the type of riding I do is more off roading fun. My WR is overkill but I like overkill. I don't ride close to its limits.
  • woods-rider
Posted October 30, 2013 - 07:45 AM
I had a hard time starting mine after a somewhat recent valve adjustment that included a 165 shim on an intake valve. We hook the tuner to it at the shop and discovered I had 174 hours on it. Probably time for new valves.
No way should you need new valves after only 174 hrs unless you are running no air filter or for some reason are sucking in a lot of dirt.
  • cwallershasta
Posted October 30, 2013 - 08:14 AM
No, I change it after every ride.
  • mch
Posted October 30, 2013 - 09:42 AM
I ride a YZ450F too that starts in 1-3 kicks and I don't think I would buy another bike if it didn't have electric start.
  • Ride-n-Hard
Posted October 30, 2013 - 08:30 PM
After you used your new fi diagnostic tool and adjusted the co, did you recheck your fi map using the gytr tool? I was woundering if maybe the fid tool is setting the base map and the gytr is and over lay "tweek".
Is there any other co settings you can access?
  • thirdcoaster
Posted November 06, 2013 - 11:32 AM
I ordered one of the SYM diagnostic tools based on the reports in this thread.  I hooked mine up and powered it off of the WR's battery.  When the diagnostic tool comes alive, it has two options on the screen: Language and Diagnostics.  When I select diagnostics, the screen indicates "connecting" but nothing happens; it just returns to the Language/Diagnostics screen.  Am I missing something here?
  • boston460
Posted November 06, 2013 - 01:17 PM
Strange, when I power mine up it has DTC and below that Diagnostic.
Try this, with the bike turned off plug the diagnostic tool in, select diagnostic with the M button and whilst it's trying to connect turn the ignition button on but don't start the bike. (This is how it requires you to access the different parameters) Hope this helps
  • vlxjim
Posted November 06, 2013 - 03:35 PM
Yea you need to power up the bike and then pick diagnostic. At some point it will tell you to to turn the bike off.
  • thirdcoaster
Posted November 06, 2013 - 04:20 PM
I have tried every sequence I could think of...powered, not powered, etc. I guess I got a dud.
  • vlxjim
Posted November 07, 2013 - 08:11 AM
It should tell you on the screen to power on or off. Is it plugged in right?
Edited by vlxjim, November 07, 2013 - 08:58 AM.
  • vlxjim
Posted November 07, 2013 - 08:14 AM
When you turn off the bike does the unit stay on? It should if its powered off the battery right.
  • thirdcoaster
Posted November 07, 2013 - 09:59 AM
It is plugged in correctly.  The battery powers the unit independently of the ECU lead.  The only thing on the screen is "Language" (UP) and "Diagnostics" (DOWN).  Pressing the "down" button makes the unit attempt to connect "Connecting", and then it returns to the original screen after maybe 10 seconds.  It never connects.
  • mch
Posted November 07, 2013 - 12:53 PM
Do you have the aftermarket ECU?  I'm not sure it's needed, but I believe the stock ECU is locked for all aspects of programming.
  • thirdcoaster
Posted November 07, 2013 - 03:07 PM
Competition ECU was installed as soon as I took delivery of the bike.
 I split the case of the EFI programmer at lunchtime.  It is really poorly made (kinda what you expect for little $$) but the circuit boards appear to be OK.  I wonder if the unit I received doesn't have the right program in it.  Tonight, I plan to check the connectors to make sure the wires are making contact.
2012 wr450 plastics by Fvmcboy99
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • 3 replies
2012 WR450 IMS fuel tank by Dave WR450
  • Hot  30 replies
2012 wr450 exhaust? What fits by Fvmcboy99
  • 20 replies
New '11 WR450 or '12WR450 by new605guy
  • Hot  76 replies
GYTR/FMF Pipe Installation 2012 WR450F by Andrew Puetz
  • 2 replies
