Starting problem
6 replies to this topic
  • spyderfrode
Posted August 12, 2012 - 02:56 AM
I have a problem.
When i hit the start button on my 2003 wr 450 nothing happens.
My battery is new,i have a new starter solenoid.i have checked the switch and it is ok.what could be wrong.i have no click in starter relay.
  • MANIAC998
Posted August 12, 2012 - 03:30 AM
Is the bike in gear? There's a safety switch built into the clutch perch, so that the bike won't start in gear. Could it be that? Need more info.
  • spyderfrode
Posted August 12, 2012 - 05:41 AM
No,it is in neutral.
Any other suggestions??
Does the starting button go straight to the solenoid?
  • spyderfrode
Posted August 12, 2012 - 05:42 AM
And the starter is okay.i tried to put 12v straight to the starter + and it starts the engine
  • miweber929
Posted August 12, 2012 - 05:52 AM
The starter button goes to a relay which fires the starter.
Check the switch.
Check the relay.
You should be able to track down the issue between those two items.
  • spyderfrode
Posted August 12, 2012 - 07:18 AM
Where is the relay on the bike?
  • spyderfrode
Posted August 12, 2012 - 01:01 PM
It works know.a cable that goes in a relay behind the battery was cut of.
