Lower end bearing and seal kit?
Started by
sikmajik
, Aug 11 2012 06:29 PM
12 replies to this topic
Posted 11 August 2012 - 06:29 PM
Has anyone come across a lower end kit? I want everything for my 97, I wasnt able to find one googling, on ebay, or any online stores...hoping I dont have to order everything individually.
Posted 12 August 2012 - 07:32 AM
I dont need a crank, I want all the lower end bearings and seals, you sure I should take the top end off to get to the bottom end?....thanks for your help.
Posted 12 August 2012 - 08:23 AM
If you just want to do the crank bearings/seals, you will need all of this. I don't know if there is a "kit" with all of this. But at least you can buy the seals/gaskets together and the bearings. Thats only 2 things. Hope this helps.
Below is a link to a complete gasket/oil seal kit.
Also a link to Crank bearings.
http://www.ebay.com/...4658c9f&vxp=mtr
http://www.ebay.com/...84f1b5d&vxp=mtr
Posted 12 August 2012 - 11:35 AM
I want new bearings and seals for my lower end/transmission....nowhere in my post does it say I want a crank/crank bearings/crank seals, although I know they are also in the lowerend, I already have them.
I was hoping there was a transmission bearing and seal kit.
Edited by sikmajik, 12 August 2012 - 11:37 AM.
Posted 12 August 2012 - 11:51 AM
Don't know of any, you have to order them from Kawasaki as far as I know.
Ed
Ed
Posted 12 August 2012 - 12:05 PM
There is no transmission bearing or bottom end kit as I've recently found out having to replace all bearings in my cases.
Ordered all separately
Posted 12 August 2012 - 02:33 PM
you half to take the top end off if your splitting the cases wich you are. are you going to get a new bearing for the bottom of the rod?
Posted 13 August 2012 - 01:35 PM
OK. It seemed like you were asking about the lower end of the motor. The transmission isn't usually referred to as the lower end. Do you just need the bearings and the countershaft seal then?
