clutch basket
2 replies to this topic
  • etuke
Posted August 10, 2012 - 02:57 AM
will a clutch basket from an 00 fit the 01 model?I found an excellent aftermarket basket from an 00 that has the gear allready installed but all I see for baskets list 01-02 for fitment.
  • etuke
Posted August 10, 2012 - 06:53 AM
forgot to mention its a yz426.
Posted August 10, 2012 - 08:34 AM
I believe it will fit. Here's the deal:
The basket, as a separate part from the rest of the driven gear assembly, IS NOT interchangeable between the '00 and '01/'02 because the driven gear assembly itself is different, and one won't fit the other gear. However, the ratio and tooth count are the same, as is the rest of the clutch, so it should fit IF it's a complete basket and gear assembly.
