My 2000 TC 610 was running fine until the weekend when it cut out on tickover and has not started since. During normal fault finding I noticed that the spark was very weak and has now vanished altogether. Does anyone know how to tell if the CDI has failed or the generator has gone? I have measured the reistance of the excitaion coil and the pulse coil, they are about the same (5 ish ohmes). When I measure the voltage coming out I get 1V from one of the coils and next to nothing from the other - this seems wrong. What voltage should I be getting? Any ideas would be much appreciated. Thanks. Andy.
TC 610 has no spark
Started by
andyparsloe
, Aug 09 2012 02:38 PM
9 replies to this topic
Posted 09 August 2012 - 04:18 PM
Check the magnet ring inside of the flywheel first, they are notorious for slipping inside of the flywheel.
Posted 10 August 2012 - 04:54 AM
Hi there. I have checked the rotor and the magnets all seem solid to me. I have seen a lot of info about these coming loose but I'm not sure thats the problem here. Is it obvious when they are loose?
Posted 10 August 2012 - 02:12 PM
Just hold it between knees, put fingers inside try to pull them out, be carefull if it starts to come out leave it alone and give me a call. I've fixed hundreds of them
(714)540-2920
Later George
(714)540-2920
Later George
Posted 11 August 2012 - 05:23 AM
Thats great advice George, just tried it and they are indeed loose! Now we have the problem of sorting it, I'm in the UK .....
Many thanks
Andy
Many thanks
Andy
Posted 11 August 2012 - 10:05 AM
Ok, thanks for that. I'll give you a call on Monday George, cheers.
Posted 14 August 2012 - 05:59 AM
This is a simple DIY fix, i did it with mine a couple of months back. total cost about £3 for some epoxy resin. I will post up pics and instructions later.
Posted 21 August 2012 - 04:07 AM
Thats great information, thank you. I've already sent mine off to George which is fine.
