suzuki rm 125 need help on the year it was made plzz
9 replies to this topic
  • hopedope
Posted 08 August 2012 - 08:27 PM
Posted ImagePosted ImagePosted ImagePosted Imagethe only numbers on it is on the steering neck its rm125-92813 and the other is on the motor its rm125-93147 plz help thanks ok i posted pictures guys help plzz
Edited by hopedope, 09 August 2012 - 09:49 AM.
  • shawn1331
Posted 08 August 2012 - 09:45 PM
Maybe a 93? Specify how old you "think" it is. Like 90's 80's. If it's 90's it's most likely a 93.
  • hopedope
Posted 08 August 2012 - 10:11 PM
it looks alot like a 1979 but im not sure
  • shawn1331
Posted 08 August 2012 - 10:42 PM
I can;t help you then, usually it goes by the first 2 or last 2 numbers on the engine in which case it would be a 93. But if your saying it looks like a 79 then no chance it's a 93. Post a picture maybe?
  • hopedope
Posted 09 August 2012 - 09:00 AM
ok im going to post some
Edited by hopedope, 09 August 2012 - 10:07 AM.
  • JCollins6695
Posted 09 August 2012 - 11:38 AM
NOT a 93, much older.. I know they changed the shock setup in the mid-late 80s. My guess is a mid to late 70s model. As for exact year, I suggest you check out Bikepics.com and start comparing pictures. Good luck!
  • mxwiz
Posted 09 August 2012 - 12:04 PM
That would be a 78, 79 or 80 RM125 the 1978 was the first year for the aluminum swingarm and 1980 was the last year for the twin shocks . In 1981 Suzuki went to a single shock full floater system.
Hope this helps some at least it gets you a lillte closer to the correct year.
  • TurboChainsaw
Posted 10 August 2012 - 06:48 AM
heres a 93 RM 125 Posted Image
heres a 1978 Posted Image
my guess would be late 70's or early 80's as mxwiz said
  • SmokinJoe90
Posted 12 August 2012 - 06:37 PM
Definetly a 78 thru 80 model I used to have a '80 and I would say by the shape of the gas tank it's very likely it is a 79 or 80 model which where nearly the same bike. It's definetly not any newer then that the '81 model went liquid cooled and to a single shock setup.  I believe those shock resivoir hoses should be running behind the frame tubes not in front like they are now in those pics.
  • wallypix
Posted 13 August 2012 - 05:45 AM
http://www.suzukicyc...les-1a_1200.jpg
you should have known..
