15-38 and 9000miles. would my odometer be wrong because of gearing? how many miles did i really go?
7 replies to this topic
  • 707LAKE
Posted 08 August 2012 - 05:07 PM
so i rode 9000 with the 15-38 sprockets on my 07sm, which means my mileage on my odometer is wrong? correct??
is there a website that can give correct mileage or anybody know how to do the conversion?
Edited by 707LAKE, 08 August 2012 - 05:08 PM.
  • UFboostedgator
Posted 08 August 2012 - 05:12 PM
Since the speedo pick up is on the front wheel, changing gearing would not affect the speed sensor. On the other hand, the factory speedo is usually off a little anyways so that may account for some change. I know that at any speed indicated on the computer, I am doing about 3-5 mph under that.
To make it worse, I have heard that even though our factory speedo is off the odometer it is actually accurate for mileage.
Edited by UFboostedgator, 08 August 2012 - 05:16 PM.
  • cdnsnowboarder
Posted 08 August 2012 - 05:15 PM
I'm pretty sure odometer is in front wheel so gearing shouldn't have any effect.  Front wheel size however will.
  • 707LAKE
Posted 08 August 2012 - 05:54 PM
:thumbsup:   haha way to make myself look dumb, i even knew that the odometer was on the front also, i should have put more thought into it! thanks
  • Knobbyaddiction
Posted 08 August 2012 - 08:51 PM
Its a common question, I asked it once
  • Craigo 485sm
Posted 08 August 2012 - 10:32 PM
You may have done way more, depending on how much riding you do on the "rear wheel only"..... :thumbsup: :blink:
Edited by CraigoDRZ485sm, 08 August 2012 - 10:32 PM.
  • darkshadow
Posted 09 August 2012 - 01:24 AM
With the stock computer, although you cannot adjust the speed without changing pick up but you can still calibrate the odometer.
Go out with one of your friend for a long ride and calibrate it. if you get a different height front tyre or as your front tyre wear your odometer will not work properly.
  • hinksy
Posted 09 August 2012 - 04:15 PM
You can adjust the standard computer for a percentage of actual miles done , you didnt accidentally press the wrong button ? I know I did , that is how I found out about this function , greg
