Quick ride with leaky left fork seal?
6 replies to this topic
  • studaddy
Posted 06 August 2012 - 05:38 PM
[font=helvetica, arial, sans-serif]Promised my son a ride tomorrow...my 09 450x has been seeping several ounces from left outer tube seal...will it harm to ride lightly or can i easily/quickly add a few ounces??[/font]
  • Cr125r07
Posted 06 August 2012 - 05:41 PM
Take a piece of plastic or a film negative, stick it in and run it around the seal. Mine does this every so often and usually theirs dirt or small debris in there causing it to leak.
  • jjhubbard15
Posted 06 August 2012 - 05:54 PM
if you cant get the crud out of the seal then pull on the spring around the dust seal and twist it off a little tighter, cut the excess off, 60 percent of the time, it works every time
  • revitup
Posted 07 August 2012 - 08:17 AM
Learned this last year.  I tried the Seal Mate a couple of times but couldn't stop the leak.  Try the Motion Pro Seal Mate, film method, or Seal Doctor (http://www.riskracin...octor_Page.html) first to at least clean it out.   Put some oil in the bleeder hole.  Slide down the dust seal.  Take small piece of paper towel and roll it up really tight.  Fit into the seal gap the whole way around.  Slide dust seal back up.  Got me through practice and 6 motos that day :-)
  • TxKX06
Posted 10 August 2012 - 02:24 AM
You're not going to hurt your fork by taking an easy ride on your bike like that. As long as you're not jumping it and and compressing it real hard then you have nothing to worry about. Give your son a ride :thumbsup:
  • crazy_dave
Posted 10 August 2012 - 02:45 AM
^^^^THIS^^^^
  • phatplat
Posted 10 August 2012 - 03:39 AM
I found a chunk of buisness card in my seals while changing them this weekend.
