i think my 426 needs rejetting... help me out with how!
9 replies to this topic
  • Octanee
Posted August 04, 2012 - 07:47 PM
hi guys, got a 426 here and basically cold it will fire up pretty darn good, i just rebuilt the sucker, high comp piston, i think its 13.5:1, replaced all valves, did auto decomp mod it idles and runs strong, however when you let off the gas, it does not pop at all, my 06 yz450f pops.... also this bike has a twinair filter,
so basically heres my problem, the big one, when its hot and you want to start it.... good luck, hot start does not help, you know what does? CHOKE! if i put the choke on then the sucker starts right up... so thats not right, now is it?
my 06 450 i dont need hot start or choke i can just give er a kick and she fires up, so i'd say my 450 is properly jetted, so i havent had to touch my carb,
and so i dont know how to adjust these carbs on these bikes and how i should go about it?
so what would you guys recommend me to touch on the carb first? since it wont start hot unless you use choke to get it going and it does not backfire at all when downshifting, must mean its really rich? or more like lean possibly?, Thanks!
  • Pooley
Posted August 05, 2012 - 12:51 PM
It is too lean on the pilot jet and/or fuel screw. Typically these bikes run best with a 45-48 pilot, sometimes even a 50, with needle around 4th clip, and a 175ish main jet. Search around on how to tune the pilot circuit and you should be pretty much all set. Not exactly what effect the high comp piston will have on jetting so you may be slightly different from what I just typed.
Edited by Pooley, August 05, 2012 - 12:51 PM.
  • etuke
Posted August 05, 2012 - 01:28 PM
mine came with stock 42 pilot and a 165 main.I had to drop the pilot to a 40 to get it to run right.I used to have to use hotstart all the time when hot and it would stumble at low rpm riding.40 pilot made her run awesome and haven't used the hotstart after to get her running.During no throttle coasting there it is a lil bit of popping.
  • Octanee
Posted August 05, 2012 - 03:48 PM
ok good to know for a base line, the 42 pilot or a 40, is lower number = richer or leaner? and needle position, down deeper in hole = leaner and higher = richer correct?
  • etuke
Posted August 05, 2012 - 04:37 PM
40 would be leaner and further down the needle sits is leaner.
  • Octanee
Posted August 05, 2012 - 07:56 PM
ok well im going to assume, that if it needs choke, which = more fuel to start while hot, that it probably needs more fuel as in it runs too lean right now? would that be a good assumption? Thanks!
Posted August 06, 2012 - 06:24 AM
Recommended reading:
http://www.thumperta...ad.php?t=404426
http://www.thumperta...699#post2881699
http://www.thumperfa.../jetting.htm#PJ
http://www.thumperta...ad.php?t=327405
http://www.thumperta...ost__p__5850936
  • Pooley
Posted August 06, 2012 - 07:17 AM
Sorry, I should have been a little bit more accurate in posting some of those jet numbers. Those are for near sea level (I'm in Michigan at about 700ft above sea level), with all free mods done and a performance exhaust. Also, I ride the WR but I have my bike exactly the same as a YZ in terms of carb and jetting. I found that I was way too lean with stock jetting after all the modifications to make this thing run properly.
Edited by Pooley, August 06, 2012 - 07:19 AM.
  • Octanee
Posted August 07, 2012 - 02:35 PM
alrighty, so my best bet to start, if i think i need to Richen it up, is to lift my needle inside the carb i take it,
and grayracer thanks for the links as always!
  • Pooley
Posted August 08, 2012 - 05:22 PM
If you are having trouble with starting, start with the pilot jet/fuel screw. Once that circuit is fixed, you can move on to the needle and main. There is a stickied post that explains how to properly tune the pilot circuit. Give that a read and see how things turn out.
  • Hot  36 replies
  • Hot  28 replies
  • Hot  50 replies
