leak down test
7 replies to this topic
  • delmas
Posted August 04, 2012 - 02:54 AM
should the motor be warmed up for a leak down test
thanks in advance
Posted August 04, 2012 - 10:02 AM
The rings will seal better if it's been run for a while, yes.
  • delmas
Posted August 04, 2012 - 05:18 PM
thanks Grey. You help is much appreciated!
  • mediumdaddy
Posted August 09, 2012 - 06:28 AM
can i ask what a leakdown test is?
Posted August 09, 2012 - 08:09 AM
The engine is locked in place so the piston will not be forced down to BDC, opening a valve, and then air is fed into the cylinder through a manifold with two gauges and a restricted orifice between them. The tool shows what percentage of the air pressure leaks away. It makes diagnosing the sources of compression/combustion losses much simpler since the escape path can be located while it is actually leaking.
http://en.wikipedia....eak-down_tester
  • bryawn
Posted October 29, 2012 - 03:06 PM
What is the best way to hold the piston in place when you crank up the air pressure? Put the bike in gear and hold down the rear brake? Or a big breaker bar on the rotor? Anything else that works well? 50-100 psi can be a lot of force.
  • bryawn
Posted November 02, 2012 - 03:51 PM
bump
  • lumpy790
Posted November 02, 2012 - 08:49 PM
used a 1/2 breaker bar or a ratchet to lock it in place. This way you can listen to find where the leak is.
  • Hot  28 replies
  • Hot  38 replies
