Dumb question. Manual pic is not perfect on this.
When attaching front wheel and installing axle... there is a tab on the speedo pickup, and a tab on the right fork. Does the speedo tab go in front of the fork tab, or behind the fork tab?
I've done it both ways, and while putting the speedo tab behind the fork tab would seem to be right as it would keep the assembly from ever rotating forward with the spin of the wheel, if you put the speedo tab in front of the fork tab, the whole assembly lines up more like the manual shows, and appears to take slop out of the speedo cable so it could never bounce into the spokes.
