Headlight Mounting Bracket? Could use some help..
3 replies to this topic
  • mslow
Posted 01 August 2012 - 10:46 AM
I bought a 2005 WR450 that had the headlight ziptied to the forks.
It looks like from the parts fiche that there is a mounting brakcet that is attached to the triple clamp, at least on one side.
Can someone post up a picture of what I'm looking for?
I bought a new headlight shroud and it's pretty obvious something is missing.
Is there a bracket for each side or just one?
Thanks in advance
  • Bandit9
Posted 01 August 2012 - 11:02 AM
There should be a bracket on each side using the 2 upper fork pinch bolts to bolt down and hold bracket. The bracket on right also is the ignition mount. The left bracket has the front brake line guide/holder. Each bracket has a threaded nut for the bolt to hold the headlight shell on.
  • mslow
Posted 01 August 2012 - 11:21 AM
that explains why th eparts fiche doesnt show the right side, it's under the 'electrical' breakdown, thanks!
  • Hurky
Posted 03 August 2012 - 11:49 AM
The only pic's I have from this area are from my 2008'wr450:
