Headlight keeps blowing
6 replies to this topic
  • SEDUCE
Posted August 01, 2012 - 12:37 AM
Hey guys my headlight on my 03 WR450 keeps blowing the low beam side.
Lasts abot 3 rides and blows again. then only works on high beam.
Can anyone help out what could be causing this on what i should check.
Where is the earth for this ?
  • Chengshin Ripper
Posted August 01, 2012 - 02:33 AM
I had to replace my Voltage Reg on my 03 for the same issue.
  • SEDUCE
Posted August 01, 2012 - 02:36 AM
oh ok and it fixed it?
  • still2smokin
Posted August 01, 2012 - 05:20 AM
Yep voltage regulator. My headlight and taillight used blow up, put in a new volt regulator and have not blown a bulb since.
  • SEDUCE
Posted August 02, 2012 - 04:04 AM
Thanks guys what is the cheapest place to get one from?
  • SEDUCE
Posted August 05, 2012 - 01:01 AM
anyone used the trail tech regulator? are they are direct fitment?
  • td42ti
Posted August 05, 2012 - 01:13 AM
$150 posted off eBay for OEM plug and play,
$115 from rocky mountain (postage would be a killer though)
I imagine you could get a generic that would work aswell, after all a regulator is a regulator but you would need to ensure you found one with the same specs.
