07 YZ450f tips/tricks
7 replies to this topic
  • Sidetrack
Posted July 28, 2012 - 06:51 PM
So I just acquired a very low hour 07 YZ450f in trade and wanted the inside scoop on the bike. I don't have any direct experience with the blue bikes. My normal ride is an 06 KTM 450 EXC along with 2 strokes for years on end. Anything I should be aware of for the bike? Any 'got to change or service right away' details? The bike is all stock and I would be surprised if it had 50 hours on it. I'm gonna start off with an oil change and clean the carb through and through. From there, I'm looking for details that need to be addressed or any insight into that model year that could save me some grief in the future. Thanks!
  • Family Man
Posted July 28, 2012 - 09:09 PM
I would check the valves, change the cam chain for sure and probley install a new piston, rings circlips and wristpin just to be safe. The chain slider will rub a hole in the swing arm if left un modded, mine did. I like 95mm sag on my 07 yz450f and the forks up 5mm in the clamps. change the oil every 3-5 hrs and you should be set. Theyre great bikes, congrats.
  • Sidetrack
Posted July 29, 2012 - 01:55 PM
Wow. Full rebuild on a low hour bike? Seems a little excessive, but suppose its the only way to be sure. What is the typical top end rebuild interval for these bikes? Are the cam chains swapped out on a regular basis?
  • Slow and Jerky
Posted July 29, 2012 - 02:18 PM
Valve clearances and do the breather tube mod. Probably not a bad idea to do the timing chain at some point. Lots of people smarter than me suggest doing the t-chain yearly since they are inexpensive and relatively easy to change.
If it hasn't been ridden hard I don't think I would do a top end unless you suspect a problem. Other than that moving the forks up a little helps handling in the corners. You might want to look at the gearing depending on where/how you ride but those are just personal preference tweaks.
Posted July 29, 2012 - 06:18 PM
Read through the Common Threads sticky, particularly the oil change procedure and relevant matters. They are a very solid, very reliable bike.
Timing chains should be replaced annually or thereabouts, but otherwise, 50 hours is just getting warmed up.
  • idahoexcr500
Posted July 30, 2012 - 05:16 AM
I have the same bike. I bought is used 2.5 years ago. I have changed the timing chain and adjusted the valves. For motor work thats it. Watch the one oil filter cover bolt (well documented on TT). I rerouted the breather hose into the airbox.I replaced the stock chain guide with an aftermarket one and silconed it to the swingarm, end of noise from rattling chain. As others have said 95mm of sag works great. I had to sofen the dampening in the forks a couple of clicks.
Other than that just regular maint. These are great bikes and they work well in all types of riding. Mine has an aftermarket pipe and sliencer. Power on these bikes is really good, very smooth and easy to manage.
Enjoy
  • Sidetrack
Posted July 30, 2012 - 06:22 PM
Thanks for all the advice TT'rs!!
  • PushL1
Posted February 26, 2013 - 10:04 PM
i have an 06, the bikes are bulletproof. if it isn't broke dont fix it, i always say. i've been racing it and as long as i keep it off the rev limiter and the valves don't float everything is good. i havent had to make a valve adjustment in over a year and i ride it at least once a week for a couple hours. i recommend just the obvious... radiator braces, skid plate and grease all the linkage components really good. oh, i dont know if they changed the seal or not from 06 - 07 but on the 06 the top steering bearing dust seal leaks water really bad if you pressure wash the bike. take that apart inspect it and see if theres any pitting then grease it really good.
  • Hot  28 replies
  • Hot  47 replies
  • On January 15, 2017
  • 5 replies
