Checked my 2010 YZ450f valves today with only 47 hours
3 replies to this topic
  • Modmotoman
Posted July 28, 2012 - 03:09 PM
[color=#222222]I thought the bike seems to take a kick or two more last weekend to start when she was hot so I decided to check the valves today for the first time as I am the second owner I do not know what they were at before. I do know this is the first time they have ever been checked and there is 47 hours on the meter that is true to the bike.[/color]
[color=#222222]Intake 0.05-0.05[/color]
[color=#222222]Ex 0.09-0.12[/color]
[color=#222222]As you can see they are too tight but I am unsure if this was tight enough to affect start up?[/color]
[color=#222222]Anyhow on Hondas we tend to run them tighter then OEM specs so my question to you guy is what do you set your valves at with these 2010-2010 yz450f?[/color]
[color=#222222]Should I aim tighter then specs or right on? [/color]
[color=#222222]Also do you think these valves are walking at this low of hours? I don’t see that it ever sucked in dirt or anything by checking the intake boot.[/color]
Edited by Modmotoman, July 28, 2012 - 03:11 PM.
  • Modmotoman
Posted July 28, 2012 - 03:14 PM
dangit sorry wrong section in the forum
  • n16ht5
Posted July 28, 2012 - 07:09 PM
Loose is better than tight. I came from hondas... you are wrong.
  • MANIAC998
Posted July 29, 2012 - 03:47 AM
Run them on the loose side. There's a spec in the manual for a reason. If you want your engine to live a long & happy life, you'll keep those valves within the specified range. And stay off of the rev-limiter! The bike will last a long time by following a few simple maintenance procedures. Check the valves, OFTEN!!! Stay off of the rev-limiter. Change the oil, OFTEN!!! And clean the air filter, OFTEN!!!
For the amount of enjoyment she provides you, can't you show her a little love? Maniac
