another question? cb key
5 replies to this topic
  • yz4me
Posted September 29, 2001 - 01:29 PM
I was wonderring what size cb key you guys are using, i got some 3/16, but I think that it is supposed to be 7.5 mm. it is not as tight of a fit as I would like. I was looking at stock on MCmaster carr.com and all they had was 1/4 and 3/16.
  • UNCHeelYeah
Posted September 30, 2001 - 03:19 AM
I haven't checked the cost, but I was wondering...if you know that this is a known problem with the 2000 model, and that you will have to re-visit this key again in the future, shouldn't you perhaps consider replacing the 2000 unit with the 2001, which did away with the key and replaced it with a spline drive? I can't figure out why they used the key in the first place on the 2000 model...there are splines everywhere else on the CB mechanism. Anyway, tell me what you find out.
  • yz4me
Posted September 30, 2001 - 04:07 AM
Dude! to do that you would have to split the cases and replace the crank with a new one, not worth the 1500 bucks or however much it would be. I will spend the dollar on key stock.
  • Glen_T
Posted September 30, 2001 - 07:05 AM
Agreed! It's cost prohibited unless you sell your perfectly good 2000 and buy a 2001/2. Not an option for me. You still would loose 1500.00! I got my keystock from Stott F some time ago. On my dial caliper his stock measures 198 thousandths of an inch. A Yamaha replacement key measures just shy of 196 thousandths. I keep this stuff around along with extra gaskets in case I need them. I've replaced my keystock twice. Once with Scotts stock, and lately with a yamaha replacement. I don't think the Yamaha part will last as well, but I thought I'd try it and see.
Glen T
  • Scott_F
Posted October 01, 2001 - 05:11 AM
Glen said it. A tight fit is better. The key is 5mm, or about .198" I'll send a piece to yz4me if you want. Do not use 3/16".
  • UNCHeelYeah
Posted October 02, 2001 - 12:11 PM
ScottF,
I'd like to have a piece, if you have it. Tell me what I need to do, and I'll be happy to oblige. Thanks.
