Hi all,
This one has me absolutely stumped
I bought a good condition 1986 PW50 for my 7 year old's birthday as it would be a easy learning curve for him. He got one good run out of it and then it had trouble revving.
Start's OK, but won't rev and Start/Run switch makes no difference to either starting or running. On these bikes, the Start position should stop the bike from revving and it should only start in Start, not Run.
So, reasonably handy with bike engine I:
* Stripped the carb and clean it out (lots of varnish; is it only me that turns of the fuel taps at ride's end?)
* Took muffler and exhaust off, scraped carbon off and burned it out with a blow torch
* Took the head off and rebored to 2nd over (some scratches but also just worn out of spec), new piston, rings top end bearing
* Tested coils and replaced ignition coil (10 times out of spec. for resistance)
* Took apart all bullet plugs cleaned with contact cleaner
* Took apart Start/Run switch, cleaned and tested
* Disconnected Start/Run switch completely and tried switching with a piece of wire instead.
* Disconnected Ignition Control Unit completely
* Replaced plug (of course!
* Ran out of ideas
* Loosened flywheel and checked key; looks good
My arm's broken after burying a mate's 2011 CRF450 into a sand berm (I ride a '93 KDX200 normally; probably vintage class almost?) so really frustrating trying to fix it with a broken right arm and having these probs. still going on!
My only remaining option is to make the wiring as basic as possible (Stator to CDI to Ignition Coil to Spark Plug) to troubleshoot further.
Any ideas greatly appreciated!
~easykiwi-rider (Western Australia)
