Broke my darn header...
12 replies to this topic
  • FinchFan194
Posted July 23, 2012 - 06:12 PM
So I have an 08 and I have a LeoVince slip-on so any header from 03-09 I can make work...I actually had an 04 on at one point.
Does anyone know what the difference are between the 03-07 headers? I already know an 08 or 09 will work for sure...
Heck while I am here does anyone have one they want to sell? PM me please.
  • FinchFan194
Posted July 23, 2012 - 06:16 PM
I guess more specifically does anyone know if the ID is the same on an 06-07 as it was in 04?
Posted July 23, 2012 - 06:22 PM
If I'm not mistaken, the '07 has the same outlet diameter as the '08-'09, but it's smaller in the front 3/4 of the header, and stepped. If you're using any sort of slip-on for the '08, the '07 header should be a power improvement. I believe the outlet size of '03-'06 headers are smaller, and would need a sleeve/gasket to fit right.
  • FinchFan194
Posted July 23, 2012 - 06:29 PM
Thanks Gray, I had an 04 header on the bike(until it cracked a few years ago) and it was much improved bottom end to the stock 08 header. I have the step down gasket for the slip-on if I need it.
  • FinchFan194
Posted July 23, 2012 - 07:38 PM
Score! Located a stock 07 header from a friend. He says it has a dent, but that is better than a crack! Gray is there any threat to bursting the header with your freezer method?
Posted July 24, 2012 - 06:52 AM
I can't lay claim to inventing that trick, but no, if you leave the ends unplugged, there's no danger of breaking it. It's titanium, though, so it's wise not to rough handle it too much when it's really cold. if it's a significant dent, it will probably need more than one trip through the freezer.
  • FinchFan194
Posted July 24, 2012 - 12:43 PM
Ok cool, makes sense to me Gray.
  • FinchFan194
Posted July 30, 2012 - 09:49 PM
Got the harder fitted up Gray, but the diameter of an 07 header is def smaller than the 08-09 headers. I am assuming that 07 down to 03 are all the same size. Took some fabbing, but I got her dialed. Thanks for the help.
  • KJ790
Posted July 31, 2012 - 03:13 AM
If I remember correctly, the 07 header is larger at the midpipe than the 03-06 headers, but it is smaller than the 08-09 headers. 07 was kind of the inbetween year that has a stand-alone header diameter.
  • FinchFan194
Posted July 31, 2012 - 07:49 PM
Thanks KJ.
Does anyone have a suggestion for making a donut gasket? The one I have is working, but after one or two times of taking it off I assume it will tear apart.
  • KJ790
Posted August 01, 2012 - 02:27 AM
If you have access to a lathe I would machine an aluminum spacer like FMF uses with their exhausts. it is about 1-1/2" in length (the lengh of the midpipe-header overlap) and has an ID to match the header diameter and an OD to match the midpipe diameter. On one end it has a small lip on the inside (about the thickness of the header) to prevent it from being pushed onto the header too far, and on the other end it has a lip on the outside to prevent it from being pushed into the midpipe too far.
  • mediumdaddy
Posted August 03, 2012 - 09:43 AM
ok wait - whats the freezer trick? and does it only work for titianium exhausts?
  • KJ790
Posted August 03, 2012 - 10:28 AM
Fill the header with enough water to cover the the dent. Stand it up in a freezer so that the water will not run out, let it sit overnight and repeat as necessary. As the water freezes it expands and pushes the dent out. Sometimes you have to do it 4-5 times to get the dent out. It works on titanium or stainless headers. I wouldn't recommend it on two stroke pipes because the volume is so large on those that it tends to expand too much and split the pipe.
  • 0 replies
  • Hot  30 replies
  • Hot  28 replies
  • On January 15, 2017
