FMF Gnarly on 2006 cr250r?
Posted 23 July 2012 - 03:34 PM
Posted 23 July 2012 - 04:59 PM
Most people do a flywheel-weight and rear sprocket to tame these machines a little bit.
These bikes were made for motocross, so they have that sudden hit of power.
I know mine doesn't like to be lugged around. It has lightswitch power. Some people like it, some people don't.
I always liked it.
Posted 23 July 2012 - 06:40 PM
Mill .025" off the base of the cylinder
mill head the rest of the way to set squish up to .045" Stock squish is .084"
Mill combustion chamber to set compression ratio per fuel you are going to use.
Buy a pwk 38 air stricker carb for the 2000 cr250. $187 from powersports plus
This is how my motor is setup. I did all the work myself. Best 250 motor I have every ridden. Great low end torque, smoother mid. and some loss on top. But you have a pc pipe witch is a top end pipe. I am running the Gnarly. So you will have more top end then I do.
Posted 24 July 2012 - 04:21 AM
I always liked it.
I am sitll a two stroke newbie so dont take this the wrong way as I might be completely wrong, but doesnt the size and shape play a huge role in the power charactaristics of a 2t motor? As I understand it, the size and shape of the pipe dictates the speed/timing of the exhaust pulses returning to close off the exhaust port. If the pipe is tuned (shaped) to take a long time for the pulses to return to the port, It would be more efficient at low rmp's and if the pules return quickly it is better in high rmp's. I know this is all probably standard knowledge for most on here but if this is true then one could only assume that the pipe would play a huge role in the making good low or high end power. I understand that other things such as case volume, port angles, compression, and squish all come into play also. I guess I was just under the assumption that a pipe would make a big change.
Edited by kneedrag05, 24 July 2012 - 09:21 AM.
Posted 24 July 2012 - 04:37 AM
Posted 24 July 2012 - 03:22 PM
Posted 24 July 2012 - 05:38 PM
Posted 24 July 2012 - 05:54 PM
From Eric Gorr's site (exactly what Kirkes described):
Quote
Cylinder head and cylinder bases can be turned and machined to produce a powerband that is better for beginners and trail-riders. The technical reasoning is that this modification serves to retard the port timing and increase the squish velocity produced in the cylinder head. If you just want more low-end power and don’t want to spend a fortune, this is the best mod that will give you the biggest bang for your buck! Includes light diamond honing to ready the bore for new piston and rings. Send the complete top end assembly for service.
http://www.eric-gorr...t2-Strokes.html
Posted 24 July 2012 - 06:58 PM
kneedrag05, on 24 July 2012 - 04:21 AM, said:
Well, you are correct with your info here, but we were referring to the differences between a PC Works pipe and a Gnarly pipe.
It is true, you can get a 2t engine to perform differently by tuning it with the pipe, but most of these aftermarket pipes are pretty close to each other.
There is not a big enough difference to produce drastic engine performance differences. That's all I was saying.
The differences would be a slight change in the powerband at different RPM ranges. If it's important to you to maximize your powerband in the range you are looking for,
then you might want to spend money for a specific pipe. I know people who changed pipes and it made no noticeable difference that they could actually "feel".
The differences might show up on a dyno, but oftentimes we "perceive" a change because we spent money on something and "want" it to make a difference.
Most of the time, we just move the power peak around the RPM range, so it "feels" different because it hits in different spots.
Some like a quick hit, other people like a long top-end runout. Actual "peak HP" can be the same. It just feels different in different RPM ranges.
Kirkes is correct also. These engines can benefit from a cylinder base mill and head job. CamP did the same thing to his engine, and it makes a difference.
I didn't do it to mine, because I am pretty happy with mine the way it is, so I just left it alone.
Next time I have to do a top-end, I will probably do the cylinder base mill on it.
I run race gas, so I don't worry about detonation.
Posted 24 July 2012 - 09:53 PM
Posted 24 July 2012 - 10:40 PM
Posted 21 February 2013 - 08:02 AM
did you have to run race gas after milling the cylinder and head? how would the setup be if only milling the cylinder?
Posted 21 February 2013 - 04:06 PM
But real gas is getting harder and harder to find. I will the switch to 100LL and bump my comp. up to make better use of that fuel.
Posted 21 February 2013 - 04:48 PM
shootz, on 21 February 2013 - 08:02 AM, said:
I have an 07 with only the cylinder base milled .030". It requires 100 octane fuel, minimum. If you want to run pump gas, you need to add 3cc of volume to the head's dome.
Edited by CamP, 21 February 2013 - 04:51 PM.
