Is your RMX hard to start?
8 replies to this topic
  • Hertigen
Posted 21 July 2012 - 07:47 AM
Hi!
Mine is very hard to start when the engine is cold (first start of the day). sometimes i have to use ether to get it running.
it starts easy afterwards
I run the bike on 98 octan fuel and have unrestricted airbox and cherrybomb
any ideas to make it start easier?
  • hm450
Posted 22 July 2012 - 08:59 AM
Usually a such issue is linked with valves
  • raulico
Posted 23 July 2012 - 11:22 PM
starting cold, and in sweden.... do you mean at -20°C???? ;-)
as HM said, valves and cam chain could need a check...
ciao
  • Hertigen
Posted 24 July 2012 - 09:09 AM
Hi =)
Actually when i was winter driving it was easier to start (-15), man its scary to drive on snow, never now if it will bear or not.
will check the valve clearance and chain tension when i come home
  • farmernz
Posted 27 July 2012 - 12:58 AM
i had this trouble and i found that i had to turn the black choke/ idle knob on the carb a few clicks clocwise or anti clock wise, (you usually pull it out to start when cold but it also turns to adjust idle). mine also runs better below 0 degrees.
  • JCollins6695
Posted 10 August 2012 - 08:42 AM
4 Strokes tend to be hard to start in general. As people mentioned that valves are typically the most common issue as it pertains to starting problems. The timing chain (as someone mentioned, once again) can also cause problems. If you feel capable, pop off the valve cover and see if the timing chain is still tense. If not, that's could be a problem.
Also, carb problems can also be a problem. If the temperature varies a lot from winter to summer, then you made need to adjust your fuel screw a little. My assumption is it's a little rich (if it's hard to start), the fuel screw should be located on the bottom of the carb, on the side closest of the head, in the middle. Tighten it a 1/4 turn, if it doesn't help, set it back to what it was.
  • Col 84
Posted 15 August 2012 - 01:03 AM
Is the RMX 450 not EFI ??
  • suzukimx256
Posted 15 August 2012 - 02:17 PM
The RMX450Z has EFI. :thumbsup:
  • ickfinger
Posted 20 August 2012 - 02:44 PM
try switching down to a lesser octane fuel, 92-93 max. Higher octane fuel burns cooler. Had this exact problem with an crf100, changed back to pump gas 92, and it fired easy
