2010 450F - Aluminum skid plate - that uses stock mount locations?
7 replies to this topic
  • rdefonce
Posted July 20, 2012 - 09:25 AM
I currently have the carbon-fiber Lightspeed plate which uses the stock hardware/mounting locations. It's SO easy to remove for oil changes, etc.
BUT, for seriously rocky off-road stuff (going to Col soon) I want an aluminum plate . . . . that uses stock mounting locations.
I figure there's GOTTA be one out there, such as the GYTR, but there's no indication that one uses the stock mounting locations. They only show a picture, nothing about how it mounts, etc.
  • drtrcr400
Posted July 20, 2012 - 08:05 PM
The GYTR plate uses the stock mounts. No clumsy clamps. I love mine.
  • FinchFan194
Posted July 20, 2012 - 10:56 PM
Seems like most skid plates use stock mounts these days.
  • rdefonce
Posted July 21, 2012 - 08:12 AM
Wow that's COOL! (I assume you're talking about the aluminum one) . . . I'm ordering up!
Thanks for tip!
  • rdefonce
Posted July 21, 2012 - 08:17 AM
Sorry about the re-post, but . . . you are talking about the '10 thru '12 YZ450F's, correct?
(I know a stock mount bolt on aluminum plate was available up to '09, but wasn't sure about 2010 up.)
  • the go-devil
Posted July 23, 2012 - 01:10 AM
The GYTR aluminum model #33D-F14B0-P0-00 I just installed on my 2012 does not use the two front stock location mounting holes on the bottom of the crank case. It uses a bracket that gets cradled on top of the frame rails. I found it to be a pain in the ass to try to hold and align the bracket where it needs to be while getting the bolts started, so I cut out a rectangular slot in it just big enough to have access to that inner oil drain bolt. I really don't want to monkey around with that thing everytime I change the oil.
  • drtrcr400
Posted July 23, 2012 - 06:04 AM
I have this skid plate on my 2012 YZ450. No clamps, uses the stock mounting locations. http://www.yamaha-mo...5/0/detail.aspx
  • rdefonce
Posted July 23, 2012 - 08:34 AM
Man this is confusing . . . seems like they are the same because they're both for '10 thru'12 yz450F
BUT I see one difference; the part number.
the go-devel you have 33D-F14B0-P0-00
DRTRCR400 you have 33D-F14B0-T0-00
I'm really surprised one has stock mounting locations, and the other one the typical brackets seen on most skid plates.
I will order the T0-00 version, for the stock mounting system's ease of maintenance.
Thanks guys!
  • Hot  47 replies
  • On January 15, 2017
