magura hydraulic clutch fluid
5 replies to this topic
  • txmxracer
Posted October 31, 2003 - 08:34 PM
I just installed a magura hydraulic clutch on my 400. Is there another fluid that you can use instead of the mineral oil? System is low and i need to add to it so it will get the full pull.Does anyone else have this set up and do you like it? thanks shane
  • sabin
Posted October 31, 2003 - 11:46 PM
Ask the KTM forum thay must know. BTW DO NOT put brake fluid or it will leak!!!
  • Indy_WR450
Posted November 01, 2003 - 04:25 PM
ATF fluid works fine or Baby oil :)
  • MXOldtimer
Posted November 01, 2003 - 05:48 PM
Baby oil
  • maicofan
Posted November 02, 2003 - 12:04 PM
I heard some use fork oil. With the different thickness they can adjust the feel off the clutch to their liking. Magura has its own oil for the hydro clutch. If I am correct most important is that the base is mineral or else it will ruin your seals.
  • Indy_WR450
Posted November 02, 2003 - 05:46 PM
Baby oil will work fine and it is the cheapest fluid to run. :)
