filter housing allen bolt
2 replies to this topic
  • Wyatt
Posted September 27, 2001 - 04:08 PM
I've run into a problem while changing oil. The allen head filter bolt will not thread completely into the case. The bolt went in fine during the last oil change, and it came out fine this time. I am almost positive that metal debris entered the threads when I removed the filter.
By looking, the threads don't appear to be damaged and I may be able to use a tap to remove the debris without damaging the threads.
I did a search and found a post on this same subject earlier this month, and I know that a helicoil will fix the threads if the tap doesn't work.
I have two questions.
First, is this common and is there any way to avoid this happening again? In the previous post Scott F said that Ty Davis recomended fixing this problem with a set screw. Has anyone done this? How do you do it?
Second, if I have to use a Helicoil, I know I have to remove the entire side cover. Is there anything special I should know before doing this? I don't like surprises.
  • Scott_F
Posted September 28, 2001 - 05:06 AM
Apparently, there is a hole that drains from the filter cavity into the threaded hole that the allen bolt goes in. It is that hole that Ty Davis blocks. I would call him and ask them what they do.
  • Glen_T
Posted September 28, 2001 - 05:08 AM
It's not a big deal. If you've never used a heilicoil before follow the directions carefully and you will have no problems. When you remove your side case, you may want to have a spare gasket available in case you damage it. I've had my side case off twice and still using the original gasket. If you install a heilicoil, the heilicoil will hang up on an oil galley when you are installing it. A pair of very long, very skinny needle nose pliers works well to get it past that point. If you have more questions feel free to contact me.
GLEN
tidermange@ocsnet.net
  • Hot  28 replies
  • On January 15, 2017
  • 5 replies
