Carb O Rings
8 replies to this topic
  • PNA
Posted July 15, 2012 - 09:15 AM
My '05 WR450 has a fuel leak. The brass 90 degree fitting for the gas line to the tank has o-rings sleeved into the carb body, and they've failed. This has happened once before and the local Yamaha dealer could only supply generic rings they had in stock. When they've looked at the parts computer, the diagram doesn't show this spigot separated from the carb body. Anybody else have this problem? Might have to call Yamaha's tech center and do some hollering tomorrow.
  • ADVRider808
Posted July 15, 2012 - 11:17 AM
You're looking for:
O-ring, fuel joint
W9351-13057
For a Keihin FCR MX39
Parts diagram: http://www.sudco.com/fcrmx.html
You can get this from Carb Parts Warehouse: http://www.carbparts..._parts_list.htm
Have fun,
Ken
  • PNA
Posted July 15, 2012 - 05:54 PM
That's a Huge help. Thanks very much!
  • Just_a_trail_rider
Posted July 15, 2012 - 06:58 PM
You're looking for:
O-ring, fuel joint
W9351-13057
Have fun,
Ken
be sure to order a couple of these things....
  • GCannon
Posted July 16, 2012 - 07:33 AM
On thing i found is that Yamaha does a poor job of making the rubber carb parts avalible.
For the same year Honda 450X you can buy a 25$ carb kit with all the rubber parts including those elbow orings (there are two) and save the rest of the seals for midnight carb repair.
  • PNA
Posted July 16, 2012 - 11:47 AM
I called JD Jetting since they're here on the West Coast. They stock these and have some on the way.
Posted July 16, 2012 - 12:00 PM
Tell your dealer you want 3 of PN 3TJ-14564-40-00. Or, tell the parts guy to look them up for an '07 WR450F instead.
  • dustdogg
Posted July 18, 2012 - 01:26 PM
I used one from a Honda CRF 450 when my WR 426 started leaking. Dealer had it in stock - Brass fitting with O-rings was cheaper than just the O-rings from Yamaha.
  • PNA
Posted July 20, 2012 - 05:48 AM
I checked that on-line. You're right, they do show those rings w/part #. Thanks, guys.
