gear to start in
3 replies to this topic
  • sirthumpalot
Posted September 27, 2001 - 01:02 PM
What gear do you all start the race in? I haven't started a race yet but I'm thinking of using 3rd. It seems like 2nd would spin to much to be worth while. The track where I would race has a short cement starting pad and the first strait is what I would consider medium to soft dirt.
Thanks!
  • Bill
Posted September 27, 2001 - 03:13 PM
I have been practicing my starts and per an article I read. I use 2nd, both feet in front of the pegs and leave them there until I have to shift. Use the clutch to reduce wheel spin and if you can, use your heel to kick it into 3rd and then feet back on the pegs. Not that I can even come close but, I'm a try'n.
Bill
99 WR400f, YZ timed, MX-Tech suspension, Scotts steering damper, White Bros E-Series (12 discs), tapered header and a/f. Kouba T-handle for the fuel screw. Works Connection billet throttle tube and frame guards. Cycra Pro-Bend, triple clamp mount handguards. Thumper Racing rad guards, Renthal Jimmy Button highs, YZ Tank and IMS seat, YZ number plate, odo removed, de-octopussed (Thanks Clark) EKP #4, 50PJ, 175MJ, 100PAJ and 65 SJ at 500-1000' Thanks James Dean!
  • yzernie
Posted September 27, 2001 - 05:17 PM
Depends how long the start straight is. On a long start I use third but, it takes alot of practice to get it right. On shorter starts I use second as I can usually stay in second while the 2 strokes have to shift.
The bottom line....practice...practice and more practice.
Ernie
Life is too short, work hard...play hard
Sponsored by Yamaha of Cucamonga, Larry Roeseler's Stroker Fourstroke Speed Equipment and Answer Racing
  • Boit
Posted September 27, 2001 - 09:24 PM
Second gear is what I've settled on. Since I pay for all my own expenses and I'll never be a pro, it's not worth the extra clutch wear to use 3rd gear on starts.
  • Hot  36 replies
  • Hot  38 replies
  • 0 replies
  • Hot  50 replies
  • 10 replies
