Help! 09 YZ450 Rear Wheel on 06 WR450
3 replies to this topic
  • woods-rider
Posted July 13, 2012 - 06:26 AM
I have a complete rear Warp 9 rear wheel for a 2009 YZ450 and want to use it on my 2006 WR450. The bearings I.D. on the hub are too large for my WR axle so I am hoping that I can just swap out the bearings to a different size. The Warp 9 hub is supposed to accept OEM bearings. Does anyone know what side bearings I would need or know the O.D. and width of OEM 2009 YZ450 bearings and the I.D. of OEM 2006 WR450 bearings?
  • ADVRider808
Posted July 13, 2012 - 10:54 AM
Your 06 WR takes 2 different bearings in the rear wheel, while you 09 YZ wheel has three bearings (all the same)
2009 YZ450 rear bearing (needs 3)
93306-90510-00
2006 WR450 rear bearing
93306-27212-00
93306-07202-00
Might want to check and see if you can use the YZ rear axle instead of swapping out the bearings. Give All Balls a call and ask about the dimensions, they may have a workable solution for you. 888-228-3323
Let us know how it works out.
- Ken
  • ADVRider808
Posted July 13, 2012 - 10:59 AM
On second thought, did you give Warp a call and ask? (801) 699-7979 Their website indicates that some of the Yamaha wheels they make will work with the WR, while some will not.
  • woods-rider
Posted July 13, 2012 - 12:24 PM
I contacted Warp and they said they have nothing and weren't helpful getting bearing dimensions.
