'98 stator
6 replies to this topic
  • BrandonW
Posted October 31, 2003 - 08:20 AM
I pulled off my stocker,a nd up-graded to a '00 WR stator, which puts out about 50-60 more watts.
Question is, is my old stator worth anything to the YZ guys? Will it fit on and give them the ability to run lights?
Thanks!
  • PumpkinHumper
Posted October 31, 2003 - 09:56 AM
Yes it will work on a yz. Granted it has less wattage than the newer models which it sounds like you already found out IE your upgrade.
Im told it needs a small mod to work with the yz CDI.
MOD
  • Thumpleupagus
Posted October 31, 2003 - 01:13 PM
Brandon, are you thinking you'd like to get rid of the old stator? I don't need much, just would like to be able to license the bike-no real need for lots of wattage... What's it worth to you?
  • BrandonW
Posted October 31, 2003 - 02:12 PM
Hey Thumple,
Yeah, I want to pass it on. It works fine, just does not push out enough wattage.
How about this?
My current computer is not working. I don't need the whole set-up, just the computer unit. $45.00.
Deal?
  • Thumpleupagus
Posted October 31, 2003 - 02:25 PM
Brandon, I sent you a PM... :)
  • Rich_in_Orlando
Posted October 31, 2003 - 04:34 PM
I'm not positive about this but I think the YZF also needs a new rotor (flywheel) to run the lights. Someone please let me know if I'm wrong because I have a friend with a dual-sported YZF who might benefit from this because I also upgraded my stator and have an old one lying around.
  • PumpkinHumper
Posted October 31, 2003 - 08:25 PM
If the wr stator is used on the yz then the yz will need the wr flywheen also. The yz flywheel will not work with the wr stator.
