2009 Yz450F starting problem.
5 replies to this topic
  • AustinV33
Posted July 11, 2012 - 03:29 PM
As stated in the title I have a 2009 YZ450F with 57.5 hours on the clock. My problem is that it will not start, I have got it to fire but it immediately shut off. It didn't bog then die, it was as if it was being shut off as soon as it fired. The carb was rebuilt about 7 hours of riding ago, and it has been properly maintained. The air filter was dirty so I removed that but the problem still persists, I also replaced the spark plug and still no luck. Could it be the top end, I fear it is a compression issue. I know that the top end has never rebuilt, original piston, gaskets, etc.
Thanks for your time,
-Austin
  • William1
Posted July 11, 2012 - 04:10 PM
Check the valve clearences.
  • Gunner354
Posted July 11, 2012 - 05:56 PM
-Austin
These aren't Hondas!
I have an 09 450 with over 300 hrs on it and it still starts in 1 or 2 kicks. Turn the idle up and see what happens. Check the pilot jet for blockage and make sure the fuel screw hasn't fallen out.
  • Family Man
Posted July 12, 2012 - 03:22 PM
check the pilot jet and check the valves.
  • rickallen124
Posted July 12, 2012 - 08:31 PM
Check your stator plate also. It was a known problem on the 06/07 for one of the screws to come loose.
  • AustinV33
Posted July 31, 2012 - 02:51 PM
Well I took it into the shop and they fixed it, My idle screw came loose, they had to turn it back in two full rotations. thanks anyways for the replies.
  • On January 15, 2017
  • Hot  47 replies
  • Hot  30 replies
  • Hot  113 replies
  • Hot  50 replies
