Power difference from 400 to 426
5 replies to this topic
  • Tevonini
Posted July 08, 2012 - 07:55 PM
Hey guys I am currently saving for a wr 426, but being the Craigslist junkie I am, I have found quite a few wr 400's for about 400-600$ less I'm just wondering if how much more power/speed/ tourqe the 426 has than the 400 facts would be nice but opinions are also appreciated
And are the 400's as hard to start as the 426's?
Thanks in advance
  • Pooley
Posted July 09, 2012 - 07:19 AM
I don't have any experience regarding the power differences, but don't fall victim to the "hard starting" BS. Once properly jetted, and you know "the procedure", starting is a non-issue.
  • Rot Box
Posted July 09, 2012 - 10:46 AM
I agree with Pooley my 426 is the best/easiest starting bike I've owned. They just have to be tuned right and started correctly.
As for power I have a hard time believing there is a major difference in power between the 400 and 426--or the 450 for that matter but I could be wrong. If i remember right the 426's received a bigger clutch, Ti-valves, updated carb, higher output lighting coil and larger rod bearing as well as a few other things. Not sure it thats a deal breaker or not... Sorry I can't be more help.
Andrew
Edited by Rot Box, July 09, 2012 - 10:47 AM.
  • VinceDC
Posted July 09, 2012 - 11:34 AM
I have ridden a 400 and 426 back to back and the power difference is minimal if any.The 400 has stainless valve which are more durable.The 426 has a different clutch and crank(as mentioned)that is stronger.
  • Pooley
Posted July 09, 2012 - 05:43 PM
The only thing I can think of as a difference is in power delivery. I have a friend who used to ride a WR400 and now rides a 2003 WR450. If I remember correctly he said that the 426 has more of an aggressive "hit" over both the 400 and 450. Against the 400 it was mostly due to a bit more power, lighter valves, faster reving etc, but against the 450 was likely due to the computer mapping making the power delivery a bit softer in the 450.
Edited by Pooley, July 09, 2012 - 05:43 PM.
  • vfr661
Posted July 11, 2012 - 11:05 AM
I own both a 2000 wr400 and a 2002 wr426 and I am not able to tell the power difference. The 426 has larger front disk brake and better radiator. I wouldn't let the differences in the 400 and 426 be a deciding factor in your purchase of a wr. It's best to find the best operating shape wr and get it when buying used.
