Help! '09 FE450 Starts But Doesn't Run
Posted 06 July 2012 - 07:16 AM
I have a 2009 FE450. When the bike runs it runs great. Unfortunately, it is not running. It starts and runs for about 5 seconds then shuts down. It seems the computer cuts the power. Valves are within spec, engine has 105 hours on it.
Here is what I have done to help diagnose/fix the problem
- Installed new battery
- Bypassed the roll over sensor
- New spark plug
- Ripped the entire wiring harness apart looking for breaks/shorts
- Tested every sensor per the repair manual, all are well within spec for voltage/resistance/continuity
- Checked fuel pump pressure, it‘s +40PSI, FUEL PUMP IS WORKING, all filters are clean
- No error codes are being thrown
I had other issues. Previously, bike would run great for about 1.5hrs, then start bogging, stall and finally not start again. It has left me stranded a few times this way. I thought I had the problem fixed, but happened again last weekend. The Berg fairies didn’t fix it this time, which in a way is good, because when I fix the problem this time, it should be fixed.
I am at the point where I don’t know what to do next. Everything simply tests fine but bike won’t run.
Any ideas? I need this fixed, I have missed a couple races already this season. My dream bike is turning into a nightmare.
Posted 06 July 2012 - 11:31 AM
This is about the time I take it to the nearest Husaberg mechanic!
Posted 06 July 2012 - 11:52 AM
Bike was runinng great. Since our local dealer closed up, the nearest one is 5 hours away. I am going to put my ECU on a good bike, see if it has the same problem.
Posted 07 July 2012 - 07:07 PM
http://www.ktm-parts.com/FP-HUS.html
Also....did you check to make sure the fuel injector is actually working....i.e. pull it out and when you try to start/run it ...make sure it is spitting out fuel.
beyond that I am out of ideas.
Posted 09 July 2012 - 11:57 AM
BryanK, on 06 July 2012 - 07:16 AM, said:
ALWAYS check all pertinent fuses and relays. If those front-line diagnostics check out OK then follow this:
If the fuel pump does not prime every time the key or kill button is set to RUN, and the fuel pump sometimes sounds weak and strained, THEN replace the fuel pump.
If the fuel pump primes every time the key or kill button is set to RUN, and the fuel pump always sounds the same, strong and steady, not weak and strained, THEN replace the fuel filter.
Here's the no-middle-man source for the 30mm fuel pump: http://www.ca-cyclew...el-carbs/fp-hus
Edited by OlderHuskyRider, 09 July 2012 - 12:02 PM.
Posted 09 July 2012 - 12:00 PM
Do you have a fan? Does the fan come on when the bike starts for 5 seconds? There's a possibility that the thermostat is bad and is sending a signal that the bike is so hot, that the ECU kills the pump, to save the "overheated" engine. unplug your thermostat and see if the bike remains running.
Edited by OlderHuskyRider, 10 July 2012 - 08:16 AM.
Posted 11 July 2012 - 12:02 PM
I confirmed it was a fuel problem when I could get the bike to run on carb cleaner squirted into the throttle body. It richened up the mixture enough to fire. I guess the low fuel pressure was leaning it out to much. I did see the injector was squirting, but not enough pressure to run.
The bad pump is a ca-cycleworks pump. They have been kind enough to replace it under warranty.
Posted 22 August 2012 - 06:34 PM
Posted 03 December 2012 - 05:53 AM
I found a fix until I have time to cure the actual problem, pour a squirt of gas (like 2ccm) down the intake, then it starts and runs as nothing ever happened.
