2013 KTM 300 XC vs. XC-W (the official thread)
Posted 03 July 2012 - 01:18 PM
In the past the 300's have varied in a number of ways: different frames, different forks, "old plastic", with and without e-start etc. It seems that KTM is making the two bikes more similar, which might make it a bit harder to choose which one to get.
I've checked out the stats on the KTM Web Site (which is sometimes incorrect), but still probably the best we have to go on: (I got the internal gearing off dealer site)
component XC XC-W
sec drive gearing 14-50 13-50
1st 15:31 14:32
2nd 16:25 16:26
3rd 20:25 20:25
4th 22:23 22:23
5th 25:22 25:22
6th 26:20 26:20
Weight 229
Fork WP Suspension Up Side Down 4860 MXMA CC
same
Shock WP Suspension 5018 BAVP DCC
same
rear travel 12.48 13.19
Seat Height 39.6 37.8
Tank Capacity 3.04 2.6
Starting elec.+ kick elec + kick
other number plate enduro light
Price 8,299 8,299.
So, again, assuming this is right the only differences are the gearing, the tanks, and the rear end height. I'll post the pictures below if I can figure out how, but they look almost identical.
As for the wide-ratio tranny on the W, it's interesting. If you swapped the 14t sproket for a 13t on the XC your final gears in 3,4,5 and 6 would be identical. The only difference is the slightly lower 1st and 2nd, with a bigger 2nd to 3rd gap. (The criticism of the W is often 'gappiness'.)
Is the seat height and travel difference the result of the XC having a linkage?
SO, I'll turn it over to the gurus. Hard to see that there is much in it at this point. I'm surprised they continue to offer both, really.
Posted 03 July 2012 - 01:56 PM
The XC-W is, as I understand it designed as the bike for super gnarly terrain: thus granny first and second, and the linkless suspension which is softer but more compliant in KTM-think. The XC used to be kinda the racing machine: with the closer ratio gear box and the linkage rear suspension, which makes a more progressive rear-end, for big hits like motocross or desert racing.
I'd love to see the Dirt Bike magazine side-by-side.
Posted 03 July 2012 - 11:39 PM
Also note the tank is listed at 3.00 Gal. on the XC. Only 2.5 on the XC-W.
I am in the market for a new bike and its going to be orange. Would love to see some more testing of these models once they land stateside
Justin
Posted 04 July 2012 - 12:11 AM
Posted 04 July 2012 - 01:38 AM
I i am torn between these two...
Justin
Posted 04 July 2012 - 09:16 AM
Justin
Power wise, they're the same. The open cartridge forks are a little more bump compliant over the closed cartridge that you find on the XC. I hated my 300xc-w trans especially the jump from 2nd to 3rd. Due to the 300 not being able to rev out as far as the 250, it was hugely noticeable for me. I would never buy one again for that very reason.
Posted 04 July 2012 - 02:09 PM
Posted 04 July 2012 - 05:40 PM
Muffler same no arrester.
T. clamps are billet 22 on the xc. cast 20 on w .I like these!.
I like xc trannie hands down.
On rough bike induced hack the xc suspension may be more plush,were the w. has a dead feel yet will wallow on fast rollers. w. fork springs are softer@.42nm vs .44nm. Last year the xc shock was very soft. 13???
Both have 13/50 gearing so 1st and 2nd are slower on w. this gives gap to 3rd not big deal on the 300 but stands out more in the 250.
As for linkage vs pds the new pds frame with (flex loop) has been perfected. And the inside of the shock was fixed for 09 so i see no need for 6 or 7 LB of extra moving parts for offroad mx yes.
There will be arguments on this it's just my opinon.
The w. gets lights for 13
The 300 revs as high as a 250 ........IF YOU hold it there!
Edited by E-TECH, 04 July 2012 - 05:43 PM.
Posted 04 July 2012 - 05:55 PM
Great summary. I've owned and ridden the 11 PDS and 12 linkage back to back and for me I notice more chassis overall movement on the PDS bike (just feels like it has more travel). The linkage rear end seems to ride a little lower and perhaps chatter a little less under braking. I felt the linkage bike has a broader operating range before I feel the need to spin a clicker. I like the simplicity of the PDS and the feel of the linkage (especially on the MX track). For me the PDS and linkage both work well and one is not superior to the other, just have to decide what matches your needs best. The closed cartridge forks work so well in all conditions I prefer them now.
The XCW's come with the KTM speedometer also. The new XC front fender will not accept the current KTM headlight so hopefully EE will make a new HL shell for the XC's soon.
Posted 05 July 2012 - 08:29 AM
JC69, on 04 July 2012 - 12:11 AM, said:
Thanks! Those are all interesting facts.
Edited by woz, 05 July 2012 - 08:33 AM.
Posted 05 July 2012 - 08:48 AM
According to the factory specs above the XC has 14/50 final drive, meaning a little less top speed. But I bet it's still pretty damn fast. And, of course, sprocket swaps are easy - but you'd make 1st and 2nd even higher. Might not matter for someone like a desert racer, they don't spend any time in 1st anyway. A lot of people start in 2nd to avoid giant wheelies on race starts, so it's only for getting it rolling when you are putting around. Ditto on hill climbs, I can't remember using first very often, by the time your going that slow you are pretty much doomed. (I have no trials skills)
That's interesting. It wasn't that long ago that they were all linkage-less, even the SX bikes.
Posted 05 July 2012 - 05:35 PM
also, it seems that people are saying the xcw has super low gearing for tight single track, just how tall is the 1-2 on the xc? On stock gearing, would I be idling at like 15 mph (xc) or is it just not as crazy low as the W? Is the tranny on the XC still in the normal range for trail bikes?
looks like the xc has better fork and better feedback with link rear, i just don't want to be clutch burning on slower stuff. a headlight would also be a necessity.
Posted 06 July 2012 - 09:19 AM
cmjb, on 05 July 2012 - 04:51 PM, said:
Is that right? Oh, yeah, it is! (Thinking about 10 speed bicycle for a second)...
Cool, so the "wide-range" doesn't get you more top speed, just more goat climbing gears!
Guess that makes sense, the origin of the XC is the desert racer. Everything about it is optimized for higher speed running, and it goes a bit faster as delivered stock.
Posted 07 July 2012 - 08:35 PM
originalmonk, on 04 July 2012 - 09:16 AM, said:
Are you sure of this? in the past there was different heads and CDI's, and the power difference was noticeable.
Posted 17 July 2012 - 03:24 AM
Posted 18 July 2012 - 05:13 PM
i wanna go with the xcw because pds good for 99% of my riding. OC forks are easier to mess with. 13 has headlight, taillight and speedo for street legalities. but the new graphics are kinda nice.
KTM 300 XC (2012) |
KTM 300 XC-W (2009) |
KTM 300 XC-W 2012KTM 300 XC-W 2012 |
KTM 300 XC-W 2011KTM 300 XC-W 2011 |
KTM 300 XC-W 2010KTM 300 XC-W 2010 |
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
Follow us:
