2 Stroke Oil: Castrol GTX 10-30W. Any good?
11 replies to this topic
  • Maxxed0ut
Posted June 30, 2012 - 12:21 PM
  • the gas station didnt have much of a selection today so i ended up with some Castrol GTX 10-30W oil
  • im changin the oil in my bike. this any good?
  • also ill be usin this to mix my gas.
  • Slick_Nick
Posted June 30, 2012 - 12:32 PM
Do not use it in either your premix or your transmission. I mean, it will probably be ok in your transmission, but synthetic oils don't play nice with wet clutches. Jus steer clear.
  • Local13Ridez
Posted June 30, 2012 - 12:33 PM
I used to use standard engine oil in my 2 stroke husky and it was never a problem. I never used it as a premix oil with the gas though. Let us know how it works out.
  • Maxxed0ut
Posted June 30, 2012 - 12:36 PM
Im taking back the Castrol and getting some JASO-MA certified oil. and 'm going to continue to use Havoline 2 Cycle oil (I'll just get some offline) for gas.
  • timmyp8823
Posted June 30, 2012 - 12:49 PM
Just buy some ATF for the tranny,and order some quality premix.
  • lookntoride
Posted June 30, 2012 - 02:18 PM
Shell Rotella T-6 or the non synthetic is good for the transmission.
I would not recommend using anything but 2 stroke oil in the engine.
  • CamP
Posted June 30, 2012 - 07:05 PM
If you are going to use auto oil, be sure to run 10w40, or heavier.
10w30 auto oils have friction modifiers that can cause wet clutchs to slip.
10w40, and heavier, oils do not contain these friction modifiers.
  • maxamillion125
Posted July 01, 2012 - 06:26 AM
KTM recommends 10w30 standard synthetic motorcycle oil. The best oil you could put in the gearbox is 10w30 fully-synthetic V spec stuff, that is fully ester based.
  • brianadams731
Posted July 01, 2012 - 10:02 PM
I dono about putting it in the transmission but I definitely would avoid using that as premix
  • Maxxed0ut
Posted July 02, 2012 - 01:08 PM
im going to continue using havoline 2 stroke oil as premix.
im gonna get some shell rotella 9 as tranny oil.
i brought back the castrol.
  • Mikel.Laundry
Posted July 02, 2012 - 01:14 PM
v spec. do you meen v twin type stuff for street bikes? i bought moil 1 10w 30 v twin oil and i couldnt get my bike to move at all ! i havent seen anyhting like it ! i put it into gear and i got a clunk then a no go drained it and put atf in it and boom she goes!
  • 1987CR250R
Posted July 02, 2012 - 07:14 PM
Dirt bike transmissoins are so unsensitive to transmission oil (especially the Japanese bikes). Just change it regularly. If you're ever hard up for oil, grab some ATF as it is specifically formulated for use in transmissions with wet clutches.
3 brand new in-crate 2007 CR250's to be auctioned in Vegas! by RippinCR250
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • 0 replies
2017 Beta AMA National Dual Sport Series schedule announced by Bryan Bosch
Dirt Bike   Special Interest Forums   Dual-Sport/Adventure
  • 0 replies
  • Hot  30 replies
2 Stroke Maintenance by Piledup
Dirt Bike   Make / Model Specific   KTM   KTM 2-Stroke
  • Hot  26 replies
Help with exhaust choosing by GearHeadGumbie
  • 4 replies
