Edited by i_wheelie_longer, 26 June 2012 - 06:45 AM.
Too Much Low Speed Rebound?
Posted 26 June 2012 - 06:44 AM
Posted 26 June 2012 - 07:11 AM
So I would strengthen the reb stack and ride the clicker at 10-12.
Your stock reb is 36-0,20*9 28-0,11*1 36-0,30*1 34-0,30*1 32-0,30*1 30-0,30*1 28-0,30*1 26-0,30*1 24-0,25*2 22-0,25*2
21-0.30*1
You see the 2x24.25 and 2x22.25. maybe 24.3 and 22.3 would be more reasonable. At least the newer ones come with a taper like that.
Maybe clamping on 22 is also worth a try.
Or changing 2-3 .2 shims to .25 or .3
Posted 26 June 2012 - 08:23 AM
36 0.30 12
36 0.30 12
36 0.30 12
36 0.30 12
36 0.15 12
36 0.15 12
36 0.15 12
25 0.11 12
36 0.30 12
34 0.30 12
32 0.30 12
30 0.30 12
28 0.30 12
26 0.30 12
24 0.30 12
23 0.30 12
26 3.00 12
Posted 26 June 2012 - 08:26 AM
Posted 26 June 2012 - 12:10 PM
Posted 26 June 2012 - 12:44 PM
Posted 26 June 2012 - 12:59 PM
Posted 26 June 2012 - 01:21 PM
My 350 2 extra 40.2 on reb and my clicker is fully open, should have put it on restackor:-(((
Posted 26 June 2012 - 01:23 PM
I switched from 6x36.2 to 4x36.3 on my YZ 125 with 50 N/mm instead of 46 N/mm spring and it was unrideable on my hometrack which is nasty hard soil with lots of bumps all shape and seize. Even at 18 clicks open it kicked on breaking bumps.
At the moment I ride 3x36.3 and its fine.
I dont know why the Americans here run these extrem slow rebs. Maybe because the tracks over there are shaped more often then ours?!
Posted 26 June 2012 - 01:32 PM
36 0.30 12
36 0.30 12
36 0.30 12
36 0.30 12
36 0.30 12
36 0.30 12
36 0.30 12
36 0.15 12
36 0.15 12
36 0.15 12
36 0.15 12
36 0.15 12
36 0.15 12
36 0.15 12
28 0.11 12
36 0.25 12
34 0.25 12
32 0.25 12
30 0.25 12
28 0.25 12
26 0.30 12
24 0.30 12
26 3.00 12
Works great. With the stock stack, the bike would ride in the back of the truck with the fender bobbing up and down waving to people. Not anymore. The back end is so well planted at speed in the rough now that the front end is less squirrely.
Posted 26 June 2012 - 01:40 PM
What comp are you riding with this reb?
Thats really a extreme reb stack.
General question:
Why the 36.15 shims and not on equal amount of other thickness (calculated with shims conversion)?
Edited by Vietze, 26 June 2012 - 01:41 PM.
Posted 26 June 2012 - 02:00 PM
I had the same problem on my 125 with 4 36.3 face shims. Rocks and roots were a problem even at 16-18 clicks out. I dropped to 3 36.3 and it got a lot better. I'm only running a 4.5kg spring though.
Posted 26 June 2012 - 02:03 PM
Posted 26 June 2012 - 02:30 PM
I feel most bikes come to light with their rebound stacks these days, but there is a happy medium, IMO Dave went to stiff. He used to be to soft, he needs to find that middle ground.
Edited by 455, 26 June 2012 - 02:38 PM.
Posted 26 June 2012 - 02:41 PM
I meant maybe only his oil gets the shock working properly with this stiff reb stack?
I also noticed his relatively weak comp stacks. Stiff reb and weak comp makes the rear ride very low...
