HELP~~ 2006 Crf450r
3 replies to this topic
  • crf450r191
Posted 23 June 2012 - 08:38 AM
ive had this bike for about 3 years i love her<3 and i have done reg. oil changes and air filter changes and not much else and i cannot start it this season im sure im just retared but its got low compression (i can push down the kickstart wit my hand) and and i cant start it without pushin it i was thinkin new rings or valve agustment somthing please helpp i wanna ride also i realise im stupid for not doing more maint. but im broke as &%$#@!
thanks sooo much ahead :devil:
  • Budlite
Posted 03 July 2012 - 09:38 AM
Check valve clearance and check to see it it jumped time.
  • mrmoto35
Posted 03 July 2012 - 04:27 PM
Could be a clogged jet as well. Did you drain the gas from the tank AND the carb before you parked it at the end of the last season? If not you will need clean both. You will have to strip the carb down and clean it with carb cleaner and compressed air really really well.
  • KZ4Rider
Posted 03 July 2012 - 07:07 PM
Check the compression also.  If its low leak it down. Report your findings.
