Clutch Pull, anyone know how to make it easier?
14 replies to this topic
  • bbeakley
Posted September 21, 2001 - 11:06 AM
I've got a '00 426 and I'd like to make the clutch pull easier. Anyone know any tricks? -Thanks, Brian
  • flyinguitars
Posted September 21, 2001 - 11:55 AM
I have an MSR raptor lever and perch...works great and was easy to install.
Mike
  • dhvann
Posted September 21, 2001 - 12:55 PM
I have a "Works Connection" CR type lever, works great. It has a needle bearing also.
  • bbeakley
Posted September 21, 2001 - 01:23 PM
Does the stock clutch cable work with these aftermarket levers or do new cables come with the kits? I could look, but I'm lazy :) Thanks for the replies!
  • yzf
Posted September 21, 2001 - 03:54 PM
its not like you ever need the clutch anyway on a 426 except for starts
  • flyinguitars
Posted September 21, 2001 - 05:31 PM
I still use the stock cable with the raptor. I always use the clutch for every upshift but just about never for downshifts.
Mike
  • PK
Posted September 21, 2001 - 05:54 PM
I can't say enough about how much the Hebo hydraulic clutch has helped my clutch. It makes the pull ALOT easier and I never have to adjust the clutch. I've had it on for 7 months with no problems.
  • mxcowboy
Posted September 21, 2001 - 06:24 PM
I agree totally with PK. Plus NO fade what so ever........
  • Itsamre
Posted September 21, 2001 - 08:40 PM
I was on a dual sport ride and saw the down side to "no fade" from a hydro. clutch. The guy didn't know that he was KILLING his clutch until it was totally gone, in just about the worst place it could happen. Some times that "fade" is a good warning system.
Mark...00 426 w/plates,and $4000.00 of other attachments!
  • yzf_virgin
Posted September 22, 2001 - 04:30 AM
The Raptor by MSR is the way to go. There's three different settings. Nothing else to buy and it's less than $40.
  • THEWAG
Posted September 22, 2001 - 02:11 PM
I have an "01" 426 and I used a wc pro perch w/ bearing and lengthened the actuating arm on the trans 10mm and the pull is like that of a ttr225
  • bbeakley
Posted September 26, 2001 - 06:48 PM
So dumb question: who sells Hebo clutches? I've looked all over the web and can't find any online dealers, help!! Also, anyone know if the Magura unit is better/worse/different than the Hebo?
  • Blueman
Posted September 27, 2001 - 03:16 PM
See my recent post of my "how stupid am I" story from 9/26. You may think different on your clutch story or you may not, but I couldn't resist pointing it out.
Blueman
  • MitchS
Posted September 28, 2001 - 07:26 AM
How did you guys lengthen the actuator arm?
I have a 98 YZ400 and I can't get the actuator arm out of the bike. I loosened the retainer plate but still can't remove it.
  • MitchS
Posted September 28, 2001 - 12:55 PM
How did you lengthen the actuator arm?
  • Hot  50 replies
  • 5 replies
  • On January 15, 2017
