leaky wr450 rad weer :(
3 replies to this topic
  • ecookman
Posted June 20, 2012 - 08:57 AM
A while ago I replaced the seals in the water pump because coolant was pissing out of the weer hole even when the bike was hot...and after 2 hours of work and a forced oil change, with 5 hours of riding afterwards....still does this.....any Ideas?
  • MANIAC998
Posted June 20, 2012 - 07:01 PM
Quite often, the water pump shaft itself will develop grooves in it, and will need to be replaced. Did you check the shaft for wear?
Maniac
  • ecookman
Posted June 22, 2012 - 05:19 AM
looks minty new....replace anyway?
  • allterra
Posted June 22, 2012 - 05:40 AM
Just an off hand question could you have pinched the seal when you reinstalled? I did. :ride: I also had a "forced oil change". :devil: The next time I laid the bike on it's side to save the one hour old oil change. :banghead:
