Yz 426 rebuild. What can you say about my valves?
8 replies to this topic
  • kubamtx
Posted June 19, 2012 - 12:32 PM
Hi
Due to pistone seizure I'm rebuilding my 426 engine. Con rod and piston has been rebuild 3 years ago and now I'll do even more. So pistone, con rod, cranckshaft bearings, main bearing, all selas, new water pump new cam chain and few more things.
But I don't want to spend a lot of money on my cylinder head if it is in good condition. So I've took of the valves and took a lot of pictures. Please take a look and share with me your opinion. My feeling is that thay are in good condition but I want to be sure.
Thanks for any feadback.
links below
https://picasaweb.go...feat=directlink
Edited by kubamtx, June 22, 2012 - 10:24 AM.
  • marv02
Posted June 19, 2012 - 04:07 PM
Hi
Below please find link to my picasaweb album.
https://picasaweb.go.../kubamtx/Yzf426
Link would not open for me.
  • kubamtx
Posted June 21, 2012 - 06:38 AM
Hi
Now it should work.
  • sid_125_04
Posted June 22, 2012 - 01:41 AM
nop now working for me
  • kubamtx
Posted June 22, 2012 - 10:25 AM
I don't know this link is not working properly. Now I've added directlinks so it should work perfect.
  • SWIGIN
Posted June 22, 2012 - 12:52 PM
I Don't know what I'm seeing in this picture but the face looks to be pitting. From your pictures this is the only valve that looks in bad shape as long as the stems are in spec.
Edited by SWIGIN, June 22, 2012 - 12:55 PM.
  • kubamtx
Posted June 23, 2012 - 01:05 PM
Hi
Steams are in specs.
The valves withi shining silver ring this are intake valves and both exhoust valves after celaning are looking like that:
As far as I remember they're looking exaclty the same as 70h ago.
I have this bike since 6 years. The head has been rebuild just before I bought it and I've re-shimmed just few hours after purchase and till now it's still on the same shimms. And the head is over 400h after rebuild.
  • boricua1
Posted June 26, 2012 - 08:57 AM
Like this other guy said the only thing I see is the pitting. And the other way you can check to see if they are seated correctly is by putting them back into the head and spray some carb cleaner into the intake and exhaust ports of the head and look at the bottom of the valves for any leakage.
  • kubamtx
Posted June 26, 2012 - 11:28 AM
HI
Thanks for feedback.
I've done the leak test like it is in the owners manual. So I've pured some cleaning solvent into the intake and after this into the exhoust ducts and checked for leaks- result- no leaks.
