Is my fork stack crap?
8 replies to this topic
  • Chill_MotoX
Posted 18 June 2012 - 01:22 PM
My harsh forks are rattling the fillings out of my teeth! Im getting sick of feeling every little bump through my hands and trying to figure out what is causing this..
I'm 155 pounds, riding 03 CR 250,
fork springs .43
comp-9 reb-12, 350cc oil 5w
Base valve
9-30
1-29
1-28
1-27
1-25
1-24
1-23
1-22
1-21
2-20
Spacer
4-16
Mid valve
1-16
1-10
1-13
1-14
1-16
1-18
1-12
1-18
2-20
Valve
6-20
1-17
1-15
1-13
  • mog
Posted 18 June 2012 - 01:31 PM
Why are you clamping on a 20? It should be a 18 ? The stack looks soft apart from that, what weight,  springs,  riding type ? What sags do you have?  What float on the mid?
  • mog
Posted 18 June 2012 - 01:32 PM
Sorry you put most of the info up, to you bottom it?  And we still need float etc?
  • Chill_MotoX
Posted 18 June 2012 - 01:47 PM
Sorry I'm still learning so bear with me..
I didn't make the stack, just trying to fix it )
I did my race sag per the manual, 3.9 in
Trying to get dialed for off road/ hare scramble type riding,,
No I dont bottom out except on real big landing on the track. How do I check the float??
  • Chill_MotoX
Posted 18 June 2012 - 01:54 PM
I think the float is 1.30 mm?? Measure between the bottom of the midvalve and the cup spacer?
  • mog
Posted 18 June 2012 - 01:57 PM
You need more sag,  103mm will put less weight on the forks and might help ( sounds backwards ) the float is something easy to measure but do a search on here on how to do it,  its a little tricky to explain
You could go down a rate in springs but sometimes one rate lower when tested are not enough different to what you gave ( they vary by 0.1 from set value )
Do you have the forks aligned correct?
  • Chill_MotoX
Posted 18 June 2012 - 02:10 PM
K thanks, The forks are aligned correctly... I have some .41 springs & I'll try I guess and play with the sag numbers a bit...
  • ds1434
Posted 18 June 2012 - 02:47 PM
Machining the outer edge of the mv cup down to just enough to hold the spring in is a great improvement.  The face shims hit the outer edge too easy in stock trim.  That and going to an 8.5 or 9 mm clamp in the mid as well
But keep your float at .3mm ish and maybe try a stack like this
(4)20
(2)17
    15
    13
Clamps
Bv maybe a little soft though
  • moto867
Posted 18 June 2012 - 09:28 PM
the stock base valve is a 2 stage.  i went to a single stage for a fast mxer and it was too stiff.  i ended up going back to a 2 stage, which i usually dont like to do for mx.  that particular bike likes a 2 stage for some reason.  especially for offroad.
