2004 Kx250f took cams out now need to know how to place them I'n and which marks on the flywheel to line up with the two notches on the hole you see the flywheel thru, does anyone have a pic or video? Any thing will be apprrciated !!
how to set timing?
Started by
motocross5625
, Jun 16 2012 04:02 PM
3 replies to this topic
Posted 16 June 2012 - 07:10 PM
http://teamgreencana...veClearance.pdf
http://teamgreencanada.ca/pdf/
Posted 16 June 2012 - 11:03 PM
i like to pull the spark plug out and put a small screw driver in that hole and when the screwdriver is at its highest point, i know im at TDC. then i line the cams up with the head, i was told that the exhaust dots will be slightly to the right instead of straight up and down and sideways, and the intake cam is dead horizontal and vertical. hope this helps!
Posted 17 June 2012 - 05:50 AM
When turning the crank left (CCW) it´s the second mark coming up in the hole. The first one is a just a timing mark, the second is TDC.
