Pro-Tec Mach 1 worth it?
4 replies to this topic
  • iNSaNe
Posted October 27, 2003 - 04:51 PM
Looking to put a better exhaust pipe or whole exhaust system on my '03 WR450 and came across this one
Pro-Tec Mach 1
Haven't been able to find anything about it on the web yet, just wondering if anyone had experience with it or heard anything about it. It seems a bit pricey but the gains look decent.
  • foursmoke
Posted October 27, 2003 - 07:47 PM
I'm no expert but I find it hard to believe any aftermarket exhaust will give you 50% increase in HP at 9000 rpm or any rpm for that matter. I do however like the ANS ( adjustable noise system ) or something like that.
Smoke :)
  • galant2nr
Posted October 28, 2003 - 08:44 AM
I think their dyno numbers are BS. For one thing, a stock WR450 should make closer to 40hp not 30hp. Check out this test by Dirtrider magazine on the same exhaust only on a YZ450. It only made about 4hp more than stock. Now I know that the WR exhaust is more restrictive than a YZ but 11hp? I doubt it...
Here is the link for the entire test. Dirtrider
Pro Tec Mach 1
Material: Stainless mid-pipe and end-cap with aluminum canister Style: Complete system Price: $449.95 Decibels: 105 Fit: A Weight: 7 lb 3 oz Spark Arrestor: Yes Overall Rating: C Comments: The Pro Tec lost some brownie points because the exhaust note is quite loud to the ear and the bike tended to backfire and pop during deceleration. Pro Tec does include a spark arrestor and an adjustable quiet block-off plate, but as a race pipe it can ring some ears. On the track this system is meatier down low and offers a robust surge right before the mid. From that point, the mid holds its ground compared to stock but starts to fall off and doesn't pull as well up top. This exhaust is more suitable for really tight courses or riders who don't prefer to ride much past the midrange.
DYNO RESULTS: Pro Tec Mach 1
Stock Complete
RPM TIME HP TIME HP
4500 0.00 23.3 0.00 22.3
5000 0.36 30.1 0.41 26.8
5500 0.68 34.8 0.81 32.1
6000 0.99 38.4 1.17 37.2
6500 1.31 41.6 1.51 41.3
7000 1.62 43.8 1.83 44.2
7500 1.95 45.0 2.15 45.7
8000 2.30 46.3 2.48 47.9
8500 2.66 46.9 2.82 49.1
9000 3.04 46.6 3.16 49.4
9500 3.45 45.6 3.53 49.2
10,000 3.90 44.7 3.92 48.3
10,500 4.38 43.4 4.33 46.8
11,000 4.92 41.1 4.78 44.1
11,500 5.51 39.9 5.28 41.3
  • iNSaNe
Posted October 28, 2003 - 06:22 PM
If you check the dyno results for the YF450F on their site, their results are pretty similar to what Dirtrider had as far as totals, so maybe the stock exhaust on the WR does suck that much :)
Mach 1 exhaust system on a Yamaha YZ450F
Stock(horsepower)
Time(seconds)
RPM Time(seconds)
Increase(horsepower)
19.1 0.49 4500 0 +1.3
25.1 0.89 5000 0.42 -2.1
30.7 1.24 5500 0.81 -1.6
34.5 1.56 6000 1.15 -0.2
37.7 1.88 6500 1.48 +1.3
40.4 2.21 7000 1.79 +2.7
41.5 2.53 7500 2.1 +3.8
42.1 2.88 8000 2.41 +4.6
42.8 3.24 8500 2.74 +5.0
40.9 3.63 9000 3.09 +7.7
40.7 4.06 9500 3.45 +7.4
40.5 4.51 10000 3.85 +7.3
40.3 4.99 10500 4.26 +6.0
38.9 5.51 11000 4.72 +5.5
  • iNSaNe
Posted October 28, 2003 - 09:30 PM
I read an article before that put the Rear Wheel Horsepower of the WR450F at 33HP so it seems pretty close. The green exhaust kills it. I have the Canadian version too so the baffle is welded :)
I mapped out all the power curves from that Dirtrider article in Excel, the Pro-Tec Mach 1 is 2nd best after 8.5k RPM but poor up until then. The Jardine had the best top end with medium mid range. The DSP Stainless is best through mid but lowest in top end. The Zip-Ty has a unique curve, it's almost flat at 45HP from 7.5k to 10.5k RPM and one of the best through mid-range.
