does anybody know how to remove the spring from a 1991 rmx 250 pictures would be awsome i cant figure this one out
removing rear spring?
Started by
tweek2x
, Jun 11 2012 07:21 PM
1 reply to this topic
Posted 12 June 2012 - 04:24 AM
Loosen the spanners to remove spring tension, pull the spring up and the check the lower part of the shock. This is where you can usually take apart what holds the spring, but you need a clean shock to be able to see it sometimes.
