Do FMF PowerCore 4's use factory gaskets?
5 replies to this topic
  • StryfeS13
Posted June 10, 2012 - 10:57 PM
I bought a 2002 YZ426F that has an FMF PowerCore 4 fitted to it. I noticed today when I removed it that there is no gasket that goes from the muffler pipe to the header pipe. There's just a clamp.
I looked on the microfiche for the YZ426F, and the stock exhaust has a gasket there. Is it supposed to be there? It doesn't seem like there is enough room for a gasket between the two pipes.
#12 on the diagram
http://www.clawsonmo...=2002&fveh=1113
Posted June 11, 2012 - 06:57 AM
No gasket. There usually isn't a clamp, either. most aftermarket pipes are slip fits.
  • StryfeS13
Posted June 11, 2012 - 12:02 PM
Well the fmf powercore has little slots in it you know, like it should be clamped down or something.
It leaks a little from the connection between the header pipe and muffler. Will the carbon build up seal it or something?
  • StryfeS13
Posted June 11, 2012 - 06:52 PM
Anyone?
  • briangriff321
Posted June 11, 2012 - 08:26 PM
Put a little high temp rtv in there
  • StryfeS13
Posted June 11, 2012 - 10:05 PM
What about that copper spray stuff?
