I am leaking oil out of 1 side of the fork on my 96 XR250r. Do I just need a seal kit like this:
http://www.ebay.com/...c722b11&vxp=mtr
and fork oil like this:
http://www.ebay.com/...d593895&vxp=mtr
Also what weight of oil is recommended? I am 200lbs with gear and mostly ride dirt road to work and slight trail type stuff. Definitely a noob to this 1 wheel drive things. Thanks.
Fork rebuild
Started by
MNorby
, Jun 10 2012 06:08 PM
6 replies to this topic
Posted 11 June 2012 - 04:35 AM
Should be it. But, I would also say to change the bushings as long as you will have them apart. When you separate the upper and lower legs, it can be rough on them. Make sure you have a manual handy before doing it. Someone should be able to post up a link for a free PDF download on one if you don't.
5wt oil, your choice on brand.
Posted 12 June 2012 - 05:08 AM
Ya it will work. I'd still say to use 5wt though so small bumps, rocks and roots won't seem as harsh.
Posted 12 June 2012 - 06:59 AM
Before you go tearing the forks apart, have you tried pulling the dust seals down and checking to see if it's just a piece of grit caught in the seal? Run the corner of a business card up into and past the seal lip and run it around the circumference of the seal.
Be sure to check your fork tube for nicks that can cut the seal. File them smooth.
Posted 15 June 2012 - 07:46 PM
Ordered parts from the local guy. Got seals and bushings coming and he stocks oils. Hope to start on it next week.
