sore back - is my shock too stiff?
Posted 10 June 2012 - 04:29 PM
Posted 10 June 2012 - 05:18 PM
Posted 10 June 2012 - 07:30 PM
LukeYZ426F, on 10 June 2012 - 05:18 PM, said:
Posted 10 June 2012 - 08:16 PM
Posted 11 June 2012 - 04:19 AM
mikea 2, on 10 June 2012 - 06:09 PM, said:
Posted 11 June 2012 - 04:50 AM
Posted 12 June 2012 - 07:56 AM
I had the spring replaced with a 5.4kg (two sizes smaller) and had it revalved for my riding skill and the just the spring alone made the difference. With the smaller spring on my tailbone didnt hurt anymore and riding/racing was way more enjoyable. I havn't had any issue's with my lower back or tail bone since the spring rate change.
The stock spring was just way to stiff for my weight. Albeit if you went down a couple size's in rate your problem will be solved. Being said....when you said if your suspension was to stiff...... is probably cause is that it probably is.
Posted 12 June 2012 - 11:41 AM
Posted 12 June 2012 - 01:02 PM
hondamx7, on 12 June 2012 - 11:41 AM, said:
The spring rate for me with the stock springs was also suppose to be correct for my weight but they were just too stiff. I weigh 175lbs to 180lbs and with riding gear on add 25lbs so at 190lbs the stock spring would be right for my weight cause the stock spring is suppose to accomidate a 180lb to 200lb rider.
I still went down to a 5.4kg shock spring and it really helped my tailbone and my riding,especially going through turns. The bike squats down more through the turns and now I go through the turns a lot faster.
Posted 12 June 2012 - 01:57 PM
Posted 13 June 2012 - 10:00 PM
An explanation for anyone wondering about my views on changing spring rates to accommodate "softness" :
Spring rates are often labeled as _kg per mm, meaning it takes however much force to compress it a milimeter. If you go from a harder spring to a softer spring, the softer spring (less kg per mm) will provide less resistance to the downward action of the fork than the harder one, providing a feeling of less compression dampening. This will allow the rider to bottom easier because the fork will not have the correct spring stiffness to hold them up in the stroke. However, if you do it the correct way by adjusting the compression clickers or the oil height, you will get a ride that is soft and will resist bottoming.
Posted 21 June 2012 - 09:44 AM
2) My first thought was you should do some core strengthening exercises like planks.
3) Your riding form can have a lot to do with it.
Posted 28 June 2012 - 04:58 PM
This is the kidney belt I use. Very comfortable, and for me, eliminates back pain that I suffer when I don't wear it.
Posted 29 June 2012 - 05:29 AM
Posted 29 June 2012 - 06:36 AM
Posted 29 June 2012 - 07:04 AM
Look at Stewart and Carmichael and the way they keep their butt out and you will know what I mean....... 100% guaranteed to help eliminate back strain.
Posted 29 June 2012 - 11:28 AM
Helps get better control of the bike as well standing longer into corners, in my opinion. Proper form & technique goes SOOOO far with this sport
