2011 YZ450F Camchain Stretching
9 replies to this topic
  • 08kxf250
Posted June 08, 2012 - 12:06 PM
Heya guys i'm posting on behalf of a mate who is stumped for a reason his camchain keeps stretching and jumping teeth.I've tried the search but can't find any thing that helps
As stated the bike is a 2011,first chain went at 50hrs,replaced with a genuine camchain,25 hours later that one was stretched and jumped teeth as well(he had to walk out of the bush an hour each way,get tools and take his bike apart to get it going,so not happy),so in goes a third one.....he rides pretty hard,does GNCC's put isn't a rev limiter type rider.Valve clearances are sweet,tensioner is all good....maintained to a high standard.
He did want me to ask if it is normal for the crankshaft to have end float,it is .29 mm at the moment.
For the record he is a mechanic and is pretty on to it but this has him baffled.
Any opinions much appreciated.....
Edited by 08kxf250, June 08, 2012 - 12:07 PM.
Posted June 08, 2012 - 03:02 PM
The usual cause is not a chain that "stretches", but one on which the links tighten and bind, or "kink", causing the chain tensioner to malfunction. That's usually an oil problem. (wrong oil or run too long without changing)
  • 08kxf250
Posted June 08, 2012 - 04:49 PM
Thanks grayracer.....i just spoke to him and he's been changing the oil as per the manual, for the oil he uses 10w 40 semi synthetic,how many hours per change would you recommend?......also whats your take on the end float?
Cheers Steve
Edited by 08kxf250, June 08, 2012 - 04:58 PM.
Posted June 08, 2012 - 05:29 PM
End play is from the ball bearings. .040" is pretty typical.
Regarding oil, under racing conditions, I never run two races on the same oil, for one thing. Here's an earlier post:
http://www.thumperta...97#entry2132297
  • 08kxf250
Posted June 08, 2012 - 06:45 PM
Cheers for the help mate......
  • 08kxf250
Posted June 18, 2012 - 12:39 AM
Hey Grayracer....do you mean .004"..........040" sounds alot
Posted June 18, 2012 - 06:58 AM
No, i actually did mean .040". The design of annular ball bearings is such that they have a very limited ability to control axial clearance, and the axial clearance is typically at least 10 times the radial clearance, even it a brand new bearing. A new C4 bearing the size of a YZ450 main will have around .001 radial clearance, but something like .008-.010" axial (end play). If the bearing wears to the point of having .003" radial clearance, you'll end up with something close to .040" axial. Ball bearings aren't intended to control axial play beyond that level, and are not used under conditions of high axial thrust without adding a thrust bearing or washer to the design. End play at that level is not problematic in an assembly such as the crank of a YZF. There's not even a spec. listed for it.
  • 08kxf250
Posted June 18, 2012 - 09:36 PM
Thanks for that mate.... for the record i wasn't questioning your knowledge,i don't really understand it to be honest but i'll pass this info on to my mate i'm asking on behalf of,thanks again
Posted June 19, 2012 - 06:40 AM
... i wasn't questioning your knowledge...
Question everything that you don't understand. :devil:
  • BBrown626
Posted June 20, 2012 - 05:38 PM
Check the chain tensioner. I had one that stuck. If it isn't holding proper tension the chain will jump on the sprockets just by attempting to start it.
  • Hot  50 replies
  • 0 replies
  • Hot  113 replies
  • Hot  47 replies
