im working on my buddys 04 yz250f and i need a few towque specs specifically the ones for his tripple clamps and steering stem ring nut, but if anyone can find an entire spec sheet for the bike that would be amazing. i did find a spec sheet for an 02 yz250 but i dont know if the torque specs are the same for what i need. some help would be greatly appreciated.
yz250f torque specs
Started by
eagleeyes221
, Jun 08 2012 08:11 AM
1 reply to this topic
Posted 08 June 2012 - 03:08 PM
If the bolt snaps you went too far.
Bottom Stem nut is 5.1ft.lbs
Top nut is 105ft lbs
Triple clamp pinch bolts are (upper) 17ft lbs (lower) 14ft lbs
This is for an 04 WR so it had smaller forks that year but it should be pretty close
